Turbo Leak Repair: VW Golf 3 (1Z)
togu
Post27-10-2004, 1:12    Subject: Turbo Leak Repair: VW Golf 3 (1Z) Quote
Hello.
I discovered a leak on the turbocharger. It's on the intake side.
What is the cause? Is there a leak at the shaft? The oil pressure line is located right next to it.
Image:
http://www.sammlerautos.de/turbo.jpg
The car runs well, and the turbo is noticeable. However, it already has 200,000 km on the odometer. Is there anything likely to go wrong soon?
When accelerating fully, you can see a slight amount of smoke in the rearview mirror. However, it's very minimal and only visible at night when there's a car behind you. In that case, the slightly hazy road is visible in the headlights of the following vehicle. You can't see it during the day.
If the seal on the turbocharger is leaking, oil could potentially leak into the exhaust side and cause the smoke.
Should I replace the turbocharger instead? A new catalytic converter is being installed soon, and I'm not sure if a potential oil leak on the exhaust side of the turbo could damage the new catalytic converter.
Thank you in advance for your opinions.
togu
Translated on 05-08-2026, 9:25.
Post27-10-2004, 7:00    Subject: Turbo Leak Repair: VW Golf 3 (1Z) Quote
It looks like your turbo is leaking oil.
They all do that, but the fact that it's already dripping from the compressor is quite a lot (my personal opinion - I just had my turbo out).
Loosen the intake pipe that connects to the air filter from the turbo and check if everything is still okay with the shaft.
- easily rotatable / swivels easily
- Under no circumstances should the bucket arms collide with anything!
Translated on 05-08-2026, 9:28.
wolfi_b
Post27-10-2004, 7:14    Subject: Turbo Leak Repair: VW Golf 3 (1Z) Quote
"A certain amount of oil mist in the turbocharger boost hoses is normal and comes from the crankcase ventilation system. However, if the clamp is tight, nothing should leak out. How much oil are you consuming? Tighten or replace the clamp, check the hose for damage, and if your oil consumption isn't excessive, you probably don't have anything to worry about."
You can definitely find it using the search function!
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 05-08-2026, 9:29.
Post27-10-2004, 7:20    Subject: Turbo Leak Repair: VW Golf 3 (1Z) Quote
So, my turbocharger was almost completely dry on the intake side.
Starting from the compressor OUTLET, there was already a noticeable oil buildup.
So, the oil is coming from the turbine shaft bearing.
Unfortunately, I took pictures of everything except the turbocharger (including the intake and exhaust manifolds).
In the photo of the turbo, there's so much oil that I suspect a problem with the bearing seals rather than a leak. Otherwise, it would likely be dripping at the connection to the turbo, where that increasingly narrow plastic hose connects (and there's no gasket there that can be replaced).
Translated on 05-08-2026, 9:30.
dj1
Post27-10-2004, 7:29    Subject: Turbo Leak Repair: VW Golf 3 (1Z) Quote
So, my turbos were always dry!
I'd like to get a new job or ideally switch jobs altogether when the cat comes back.
DJ.
Translated on 05-08-2026, 9:32.
togu
Post28-10-2004, 1:43    Subject: Turbo Leak Repair: VW Golf 3 (1Z) Quote
Hello.
Thank you for the answers!
I'll check the turbocharger on the naturally aspirated side tomorrow to see if there's any play in the shaft or anything like that.
I will then submit a report.
togu
Translated on 05-08-2026, 9:33.
Post28-10-2004, 20:15    Subject: Turbo Leak Repair: VW Golf 3 (1Z) Quote
Here are a few more (well-known) images from the turbocharger field.
http://www.luxus-wg.de/~martin/auto_bilder/Kruemmer/
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air leak in turbocharger pressure line, AFN engine Diesel Engine Technology
No new posts ZK auf Risse bzw Undichtigkeit überprüfen Diesel Engine Technology
No new posts Turbo beim Golf IV / ALH! Und LMM Diesel Engine Technology
This topic is locked, you cannot edit or reply. 20 km driven without using the turbo (Golf IV ALH) Diesel Engine Technology
