PD Tuning: Box & 10c Optimization
ibiza1910
Post30-10-2004, 20:25    Subject: PD Tuning: Box & 10c Optimization Quote
Sure, here's the translation:
'I know this topic has been discussed a thousand times, but I'd like to make my 1.4 TDI PD engine a bit faster. Unfortunately, a simple '10-cent' tuning solution isn't available. I'm curious to know what the risks are with cheap tuning boxes. The engine should be able to handle the extra power. Is the main problem really the diesel temperature?'
If so, is there no way to permanently cool the fuel line?
Translated on 27-09-2026, 19:06.
Post30-10-2004, 21:56    Subject: PD Tuning: Optimizing Performance and Efficiency Quote
ibiza1910 wrote:
I would like to make my 1.4 TDI PD a bit faster. Unfortunately, a simple "10 cent tuning" is not possible.
Why not? -> 10c-Fachartikel also has something for PDs (people with Parkinson's disease). However, it has somewhat worse side effects than with VPs (people with Parkinson's disease).
Where did you hear that?
PDs all have a fuel cooler icon_rolleyes.gif.
Translated on 27-09-2026, 19:08.
ibiza1910
Post30-10-2004, 22:05    Subject: PD Tuning: Box & 10c Optimization Quote
However, with some nastier side effects than with VPs...
Which one?
Translated on 27-09-2026, 19:09.
Post30-10-2004, 22:11    Subject: PD Tuning: Box & 10c Optimization Quote
ibiza1910 wrote:
However, with somewhat worse side effects than with VPs...
Which?
/viewtopic.php?t=3208, section about PDs.
Manuel Thomas
Post30-10-2004, 22:15    Subject: PD Tuning: Box & 10c Optimization Quote
'Isn't there just a resistor inside those eBay tuning boxes?'
Manuel.
Translated on 27-09-2026, 19:10.
turgumu
Post01-11-2004, 16:56    Subject: "It didn't work for me either" Quote
Increasing the boost pressure with a 10-cent piece didn't work for me, even though I followed the instructions described in this forum.
Could it be that it might not work with older engine control units (ECUs)? (Volkswagen, year of manufacture 1996, model 1Z)
ibiza1910
Post01-11-2004, 17:57    Subject: PD Tuning: Box & 10c Optimization Quote
'Isn't there just a resistor inside those so-called 'tuning boxes'?'
Manuel.
'Before I start making something myself, I'd rather just use this one.'
Translated on 27-09-2026, 19:11.
Avatar-Jan6K
Post01-11-2004, 18:26    Subject: PD Tuning: Box & 10c Optimization Quote
Do you prefer to rely on the sloppy work of others, rather than building something yourself, even if you know what's inside and that it's done properly?
Furthermore, the price of several euros for a resistor and two connectors, one of which only serves as a "dummy plug," is quite excessive.
What all of these solutions have in common is that you are not allowed to use them in road traffic.
Jan.
1Z5 CFHF / AHB H4D
Translated on 27-09-2026, 19:12.
Post01-11-2004, 18:52    Subject: Not Working? Troubleshooting Tips & Solutions Quote
Could it be that it might not work with older ECUs? (VW, year of manufacture 1996, model 1Z)
Then it was probably the wrong resistor... it's not good if you don't know what you changed.
If I were in your position, I would reinstall the original part and either try to understand the circuit in the control unit or have a chip installed.
Translated on 27-09-2026, 19:13.
ibiza1910
Post02-11-2004, 8:02    Subject: PD Tuning: Box & 10c Optimization Quote
Do you prefer to rely on the sloppy work of others, rather than building something yourself, something you at least know what's inside and that's done properly?
Furthermore, the price of several euros for a resistor and two plugs, one of which only serves as a 'dummy plug,' is quite excessive.
Jan
You're absolutely right about that. Where can I find the right connectors for it?
Is this available as a spare part from a VW dealer?
Translated on 27-09-2026, 19:15.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts MFA and Chip/Box Tuning Diesel Engine Technology
No new posts Active speakers faulty in VW Passat 35i Transmission, Chassis, Body & Interior
No new posts Power Cables: The New Must-Have Audio Upgrade Diesel Engine Technology
No new posts OBD tuning for the Ibiza ASZ Diesel Engine Technology
