AJM & LMM by ARL: Feasible and Useful?
herwigw
Post02-11-2004, 23:08    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
Good evening, everyone!
I heard yesterday that the lambda sensor (like the one on my AJM engine) from an ARL engine is compatible and 'supposedly adds 10-15 horsepower in general.'
Okay, based on my log tests, the smoke limit seems to be lowest only up to 1800, but still:
Can these parts actually fit (diameter of the intake manifold, connector, and connector pin configuration)?
If possible: Has anyone tried it, and is the characteristic really suitable for the AJM engine, or does it just make the turbo lag more expensive? icon_lol.gif
best regards
herwig
Translated on 31-08-2026, 3:05.
Post02-11-2004, 23:22    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
In my humble opinion, this doesn't achieve anything at all. It certainly won't provide a performance increase of 10% or more. Why would it? If that were the case, a closed EGR system should also deliver significant performance gains.
Translated on 31-08-2026, 3:06.
Marco
Post02-11-2004, 23:23    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
'How on earth can that possibly add 10 to 15 horsepower? In my opinion, it's complete nonsense. Who is spreading such information? Regardless, the engine control unit (ECU) will only accept limited mass airflow (MAF) values.'
Post02-11-2004, 23:52    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
Okay, I'd just estimate that the AJM and the ARL have the same LMM.
And then, the extra performance is more than just superstition.
And speaking seriously now:
How is that supposed to work: If the mass airflow sensor (MAF) is functioning correctly, it shouldn't be responsible for the engine's performance at all – how can it possibly increase it?
Therefore, NONSENSE - incorrectly placed[/size] icon_evil.gif.
Edit: The LMMs (likely referring to mass flow meters) don't have the same part numbers, but this could simply be due to the pipes they are installed in.
Translated on 31-08-2026, 3:07.
herwigw
Post03-11-2004, 8:01    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
I would estimate, based on my gut feeling, that the AJM and the ARL have the same LMM.
Therefore, NONSENSE - incorrectly stated
Thank you, Martin, Mathias, and Marco!
'According to a rumor I heard from a VW master technician (although I didn't hear it myself, but was told about it), and based on everything I've learned in this excellent forum so far, I would have considered it a myth. However, I just wanted to be sure.'
I'm planning to have the timing belt adjusted at my next mechanic appointment because the current timing is too late (unfortunately, the crankshaft pulley is already at the earliest position within its adjustment range - so the timing needs to be adjusted one tooth further, which I don't want to attempt myself). I'm also hoping to have the opportunity to test a different mass airflow sensor (MAF sensor) from an ARL engine at the same time. I might try it and create logs to disprove the common belief about it.
best regards
herwig
Translated on 31-08-2026, 3:10.
Post03-11-2004, 8:37    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
It's well-known that sometimes VW doesn't know what they're doing. However, anyone promising increased performance through a Mass Air Flow (MAF) sensor replacement would have voided my warranty. Instead, I consulted Ulf's technical article and did it myself. It's very well explained, and that way you know exactly what you're getting.
Translated on 31-08-2026, 3:12.
herwigw
Post03-11-2004, 8:57    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
It's well-known that sometimes at VW, they don't know what they're doing. However, anyone who promises increased performance through a Mass Air Flow (MAF) sensor replacement would have voided my warranty. Take Ulf's technical article and do it yourself. It's very well described, and then you know what you have.
No, no, the person who claimed that won't be able to get their hands on the Bora; I phrased that poorly.
best regards
herwig
Translated on 31-08-2026, 3:13.
Post03-11-2004, 14:20    Subject: AJM & LMM by ARL: Feasible and Useful? Quote
herwigw wrote:
Unfortunately, the NW wheel is already at the lower limit of its adjustment range - therefore, the NW needs to be rotated one tooth further on the timing belt, which I don't want to try myself
It's the same for me, even though the settings aren't (completely) maxed out yet.
If you can observe how the problem is being solved, please write it down.
I would also try it - provided that you don't have to remove the engine mount in front of the tensioner icon_evil.gif.
Translated on 31-08-2026, 3:14.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF and Performance Tuning: Is it Worth It? Diesel Engine Technology
No new posts Oil Pump Replacement: Is It Worth It? Diesel Engine Technology
No new posts Slotted Brake Discs: Are They Worth It? Transmission, Chassis, Body & Interior
No new posts Is chip tuning a worthwhile upgrade for a Golf 4 ALH 90 h... Diesel Engine Technology
