TDI T3 Bus: Warm Start Problem - Solution Code 00011
t3_tdi
Post22-09-2004, 17:03    Subject: TDI T3 Bus: Warm Start Problem - Solution Code 00011 Quote
Hello everyone,
beim Einbau eines AFN in einen VW-Bus T3 kann es vorkommen, dass es zu Warmstartproblemen kommt, wenn man bestimmte ältere Steuergeräte hat (z.B. 028 ... GT od. 028 ... CPlease provide the text you would like me to translate from German to English.
To the best of my knowledge, there are three possible approaches to address this problem.
- Tausch des STG gegen z.B. 028 .... GN
- Removing the temperature sensor.
- Recoding to 00011 (temporary code).
However, the last solution generates an error (incorrect encoding), even though the engine always starts perfectly fine afterwards.
How can I prevent an error from being generated in the TCU (Transmission Control Unit) with the latest solution?
Gunnar.
Translated on 21-09-2026, 8:29.
timm
Post29-10-2004, 1:47    Subject: TDI T3 Bus: Warm Start Problem - Solution Code 00011 Quote
I'm having the same problem, and I've even unplugged the device. Have you found a solution yet?
Best, Timm.
Translated on 21-09-2026, 8:31.
gerbi
Post29-10-2004, 17:28    Subject: TDI T3 Bus: Warm Start Problem - Solution Code 00011 Quote
-> Read channel 5 again. It might help!
No new posts TDI Conversion: VW Bus Cold Start Problems Diesel Engine Technology
No new posts Audi a3 Warmstartproblem Diesel Engine Technology
No new posts AFN, spark plug, stripped threads, help!!! Diesel Engine Technology
No new posts TDI AEL: Rough Idle - Fix & Troubleshooting Diesel Engine Technology
