Summer Light: Capturing the Perfect Glow
Zettelmeyer
Post28-10-2004, 13:18    Subject: Summer Light: Capturing the Perfect Glow Quote
Hello.
After starting my newly acquired Passat 3B with the AHU engine (built in November 1997) twice, and it barely starting each time, I'm wondering where the buzzer is located so I can check it. I assume it has one, or am I wrong? (Trendline trim level).
Jens
Translated on 29-09-2026, 7:36.
LZ
Post29-10-2004, 0:10    Subject: Summer Light: Capturing the Perfect Glow Quote
Good evening/morning.
It is usually a relay plugged into the fuse box. The part number is 3A 095 1307. Please find out, using a wiring diagram or terminal assignment plan, where the corresponding slot should be located.
http://www.passat3b.de/phpBB2/index.php
There might be something to find there, otherwise just buy a repair manual. If there's no buzzer built in from the factory, you're out of luck. It's usually not wired in. While everything can be retrofitted with the appropriate wiring diagrams, there are also more or less successful DIY solutions.
Best regards, Robert.
Translated on 29-09-2026, 7:37.
Max d. Ä.
Post29-10-2004, 9:37    Subject: Summer Light: Capturing the Perfect Glow Quote
'In my Passat 3B AFN from 04/97, the buzzer is located in the instrument cluster (IC). When I replaced the IC with one that had a Multifunction Display (MFA), the built-in buzzer was defective. That's why I desoldered the defective buzzer at that time and replaced it with a piezoelectric buzzer from Conrad. Now, the buzzer is 'annoying' again when the lights are accidentally left on, but with a slightly different tone.'
Bye.
Max.
Translated on 29-09-2026, 7:39.
Zettelmeyer
Post14-11-2004, 21:31    Subject: Summer Light: Capturing the Perfect Glow Quote
It seems like the buzzer is also present in my AI unit. Since I'm not very knowledgeable about electrical systems, it will probably stay like this for now. Has anyone ever seen a photo of the AI unit where the buzzer is visible? I don't want to cause any more damage.
Jens
Translated on 29-09-2026, 7:40.
daytrader
Post14-11-2004, 21:45    Subject: Summer Light: Capturing the Perfect Glow Quote
Does the interior light turn on when you open the door? If not, or if it only works intermittently, then I would suspect that one of the microswitches in the doors is defective.
see also, for example, here: http://www.passat3b.de/phpBB2/viewtopic.php?t=5627&highlight=mikroschalter+innenlicht
Zettelmeyer
Post15-11-2004, 9:44    Subject: Summer Light: Capturing the Perfect Glow Quote
Hi.
Yes, the interior lighting works on all doors. The fuel gauge buzzer also works. I also believe that, according to the wiring diagram, there are two different buzzers.
Jens
Translated on 29-09-2026, 7:41.
Post15-11-2004, 21:08    Subject: Summer Light: Capturing the Perfect Glow Quote
At least in the Golf, there's a double switch located on the driver's side door.
- A circuit is connected to all other toggle switches and controls common functions, such as the interior lighting.
- The second circuit is connected to the functions that should only be controlled from the driver's door. For example, the light reminder setting.
If you're experiencing the same issue, it might simply be the second ring of the switch. That's the first thing I would check, as it's a mechanical component and therefore more prone to failure.
Guste.
Translated on 29-09-2026, 7:42.
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Summer Light Bulbs: Limited Stock! Diesel Engine Technology
No new posts No Light: A Dark and Mysterious Tale Diesel Engine Technology
No new posts Tiguan AD1 LED Light On-Board Diagnostics (OBD)
No new posts Electrical Lighting: Solutions & Ideas Transmission, Chassis, Body & Interior
