Update:
I've looked in both directions.
a) Transition resistances seem unlikely, as I measured constant and almost 100% identical resistances and inductances for each individual PDE at the MSG connector, despite simultaneously wiggling the wiring harness at as many points as possible.
b) I can also practically rule out air in the coolant system. I've replaced the supply and return hoses between the filter and the engine with clear sections, but I don't see any bubbles anywhere when the engine is running.
A theoretical possibility for gas leakage in a PDE (common rail pressure sensor) could be a breach of the combustion pressure through the sensor's mounting hole into the diesel pre-injection circuit. This would require the pressure to overcome one metal gasket and one O-ring.
Something like that, in my opinion, should only be revealed by bubbles
only in the return flow.
As I said, I can't see anything.
As a final "external" option, PDE No. 3 could remain in place, and I will check this and, if necessary, adjust it to align with the others.
If that doesn't work either, the only likely explanation would be a tolerance outlier in PDE 3.
By the way, the behavior of the idle speed control (ISC) after a cold start is different from that when the engine is warm.
Average values in the LL (likely referring to a specific measurement or system) for cylinders 1-4 = 42 / 37 / 61 / 38.
Do the higher positive values now indicate shorter exposure times?
It's conceivable that copper (as a likely material for the PDE windings) has a lower resistance when cold compared to when it's warm, and that the starter battery also provides a higher voltage when cold.
But, on the other hand, isn't cold diesel less fluid than warm diesel, and therefore shouldn't it brake the movement of the PDE valve piston more strongly -> resulting in a longer engagement time
Where are the PD cracks located?
Hi Bertil and Co...
