Speedometer Sensor Location: Find It Here!
verdiener
Post13-11-2004, 18:51    Subject: Speedometer Sensor Location: Find It Here! Quote
The speedometer needle on my 1997 Passat 3B TDI AFN (81kW) flickers within a range of approximately +-10 km/h when I reach the maximum speed.
Yesterday, with an outside temperature of 2°C, the speedometer completely failed (the needle remained at zero). Once the engine reached operating temperature, everything worked again.
No error was recorded.
I'm tapping on the sensor for the speed signal, the so-called 'speedometer sensor (G22)'.
Dieser soll am Getriebe sitzen. But exactly where?
Can this be easily replaced, or does it require more effort?
Translated on 12-09-2026, 2:38.
Post13-11-2004, 19:34    Subject: Speedometer Sensor Location: Find It Here! Quote
verdiener wrote:
1997 Passat 3B TDI AFN. . .
Supplier for the speed signal, the so-called "speedometer sensor (G22)".
This should be located on the transmission. But exactly where?
On the AFN engine, it's located near the shift linkage and is identifiable as the second electrical connector on the transmission - the other one is the switch for the reverse lights.
You'll have to check whether this applies to the Passat (e.g., if it can be installed lengthwise) or not.
Translated on 12-09-2026, 2:40.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Speed sensor location: VW Golf B4 TDI 1Z (1993) Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
No new posts Austausch des RNS315 gegen neues "Discover Media" Electrical Systems, Vehicle Electronics, Multimedia
