josip77 Guest
11-11-2004, 10:07 Subject: Passat 94: Engine Control Unit (ECU) Issues & Tuning |
'Sorry, I don't speak German. I'm having a problem with the engine control unit (ECU) in my 1994 Passat (1Z TDI engine). My ECU is dead, and my car is from 2/1994. I bought a used ECU (from a Passat 11/1994, 1Z TDI, 028906021AK) that includes an immobilizer, but my car doesn't have an immobilizer, and I'm getting a P1570 fault code. Is there a way to disable the immobilizer, or is there another solution? I have VAG-COM 311-2.'
Sure! Here's the translation:
'Thanks!!'
Translated on 03-11-2026, 23:03.
matthiasTDI96 Profi-Schrauber
11-11-2004, 11:44 Subject: Passat 94: Engine Control Unit (ECU) Issues & Tuning |
As far as I know, you don't have any way to disable the immobilizer using a standard VAG COM version. However, there are ways to address this problem. First, you could try to obtain the original car key, the ignition lock, and the immobilizer induction coil. However, I think this could lead to other problems.
Another idea is to find someone who is able to disable the immobilizer. I just used Google and found this page, gti-tdi.de, and he says that he can do what you need. Perhaps you will get more information by sending him an email?
Matthias.
Translated on 03-11-2026, 23:04.
11-11-2004, 11:45 Subject: Passat 94: Engine Control Unit (ECU) Issues & Tuning |
By the way, what was the problem with your own "motorsteuergeraet"?
Translated on 03-11-2026, 23:05.
josip77 Guest
11-11-2004, 13:01 Subject: Passat 94: Engine Control Unit (ECU) Issues & Tuning |
By the way, what was the problem with your own 'motorsteuergeraet'?
My engine control unit (ECU) is working, but I'm experiencing the following problems with it:
In the measurement block, all values are in order except for the power supply, which is always approximately 2V lower than it should be (11.95V when the engine is running). When a new engine control unit is installed, the power supply is correct (12.24V, engine not running). With the old engine control unit, the symptoms include less powerful acceleration, and from 1500-2000 RPM, the engine noise is much louder (like the TDI timing is incorrect, but the timing is correct according to VAG-COM). The car has reduced horsepower, behaving more like a TD than a TDI. The MFA (Multi-Function Display) shows 2-3 liters/100km more fuel consumption than it actually is. I have tried all possibilities except for replacing the Bosch pump and the engine control unit. When I connect a 160-180 Ohm resistor with two diodes connected antiparallel between wires 2 and 3, the acceleration improves and is closer to what it should be.
Translated on 03-11-2026, 23:06.
