AJM Flywheel: Outer Diameter?
herwigw
Post16-11-2004, 11:18    Subject: AJM Flywheel: Outer Diameter? Quote
Hello everyone,
Can anyone tell me what the outer diameter of the flywheel is on my AJM MJ 2000?
In the technical articles, the clutch diameter is always specified, but I would like to know...
'I need to know the outer diameter of the flywheel so I can calculate the correct North-West (NW) position relative to the Top-Of-Throat (OT) mark on the flywheel.'
How many millimeters on the flywheel correspond to one degree of crankshaft angle?
Is there a formula for that?
Does anyone have an exact value (disassembling and measuring is rather time-consuming icon_lol.gif)?
best regards
herwig
Translated on 09-10-2026, 7:42.
No new posts Clutch Input Shaft Diameter 1Z/AFN Diesel Engine Technology
No new posts Valve Hole Diameter: Find Your Rim Size Here Transmission, Chassis, Body & Interior
No new posts Tire Wear on the Edges Transmission, Chassis, Body & Interior
No new posts Water = 100°C at the source, but only 13°C outside!! Diesel Engine Technology
