dj1 Guest
01-06-2004, 11:55 Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 |
I want to do the exhaust gas recirculation  .
So, just screw a stainless steel plate onto the manifold.
Does anyone have a sketch with dimensions for such a plate?
It would be great, otherwise I would have to measure everything painstakingly.
Thank you.
DJ |
01-06-2004, 12:01 Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 |
Just buy a coloring book and trace the designs.
Or, quite brazenly, have it shown to you, copy it, and DON'T buy it  .
m; Transparency, Teamwork
Profile PM Garage |
donalexo Profi-Schrauber
Joined: 01/09/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
CAN Support
01-06-2004, 12:10 Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 |
Hello dj1!
I would definitely buy a gasket and use it as a template for the sealing plate. Finally, you need a second gasket between the sheet metal and the flange  .
Otherwise, it cannot be guaranteed that your connection is secure. Depending on the installation orientation, you might experience leaks either on the charge air side or the exhaust side.
Alex. AUDI A3 1.9 TDI, EZ 12/96, ursprüglich MKB AGR, umgebaut zum AHF mit GT1749V-Lader, verkauft mit 250tkm
Touran 1.9 TDI, EZ 09/2004
Audi A4 Avant 2.0 TDI, EZ 03/2010 |
dj1 Guest
01-06-2004, 12:18 Subject: You're welcome |
Thank you!
I'm going to get a poem and copy it out!
DJ |
moriaty Guest
25-11-2004, 1:25 Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 |
Hey, can you explain to me why you're doing this? What's the point? And what's the exhaust gas recirculation (EGR) valve for? I had a power loss on my AFN 110hp engine. I unscrewed the hose from the valve, and then it ran better than before. Why is that? How does it work? What's the purpose? |
25-11-2004, 2:12 Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 |
@ moriaty
Have you read "The Little Fat Cupcakes"?
I don't think so, because if you had, you would have searched for "AGR" or "exhaust gas recirculation" and found so much information that you could give a presentation about it yourself.
And by the way:
Why are you messing around with parts of the car that you don't know what they're for?
That would be too expensive for me!
(P.S. I don't expect a response - just use a search engine.)
Thank you.
Profile PM Garage |
moriaty Guest
26-11-2004, 13:11 Subject: Hey, I'm new to your site, sorry. |
Yes, thank you.
My search function wasn't working, or maybe I was just too dumb to use it. But in the meantime, I now know pretty accurately how the EGR system works and why. I've never owned a diesel before. And I also know why I would want to seal it off. Through my own thinking and maybe some experimenting, I've saved a lot of money and time, because all the mechanics were looking for the problem in other places. They all had no idea. First, I checked the timing, then the turbocharger, then the catalytic converter, etc., all based on the mechanics' suggestions. It was only a Volvo owner who pointed me in the right direction. And in my books, there was nothing about the function and operation of the exhaust gas recirculation system.
I have to commend this website. It has provided me with a lot of valuable information, especially the information I was looking for. I will definitely use it again in the future, okay?
P.S.: Whoever finds a spelling mistake can keep it. |
