Fuel shut-off valve
nobes
Post22-07-2002, 21:37    Subject: Fuel shut-off valve Quote
I read this error code on my Sharan with a 110 hp engine, manufactured in 1997.
I replaced the valve. Unfortunately, it didn't work.
It starts up easily, briefly revs on its own, and there's a short burst of black smoke.
The light bulb turns on and then switches to emergency mode.
Who can help me?
Thank you, Nobes.[/code][/list][/list][/b]
Translated on 22-07-2026, 10:44.
Michael II
Post22-07-2002, 21:42    Subject: Fuel shut-off valve Quote
Did you also check the connection?
Tschüss
Michael II
nobes
Post22-07-2002, 21:46    Subject: Fuel shut-off valve Quote
Yes, the wire is providing 13 volts.
Translated on 22-07-2026, 10:45.
Michael II
Post23-07-2002, 6:49    Subject: Fuel shut-off valve Quote
Do you still have the error code?
Tschüss
Michael II
Post23-07-2002, 6:49    Subject: Error memory Quote
Are there any other entries in the error log besides this one?
No new posts Diesel Leak: Faulty Fuel Shut-Off Valve Diesel Engine Technology
No new posts LMM Failure: Fuel Shut-off Valve - Mechanical Issue Diesel Engine Technology
No new posts 01237 - Fuel Shut-Off Valve - Intermittent Fault On-Board Diagnostics (OBD)
No new posts Fuel Shutoff Valve (ALE) No Signal: Troubleshooting On-Board Diagnostics (OBD)
