Just to add, the AAZ engine has 3 outlet channels under the oil flange (engine block), compared to only 2 on the 1.6 (JR or JX). One channel goes directly to the cylinder head, and the oil and water channels are arranged differently. The AAZ has a steel gasket (the JR has a "cardboard" gasket). The AAZ has a smaller intermediate shaft gear, which leads to a higher RPM, resulting in more vacuum at the vacuum pump and more oil flow/pressure (although the drive gear, which is a helical gear on the intermediate shaft for the oil and vacuum pumps, is slightly smaller). The cylinder head cover is attached differently. You can also check out the AAZ project on the Bulliportal website. Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 05-10-2026, 7:14.
