Piston Damage? 1994 Car Repair
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
Diesel Engine Technology
View previous topic
View next topic
Author
Message
macgyver68
13-11-2004, 14:47
Subject: Piston Damage? 1994 Car Repair
Quote
I've been trying to fix the problem with my 1.0L engine for ages.
It's knocking and smoking blue.
zkd, ventilschaftabdichtung usw. gemacht. drückt das öl durch beide krümmer am 4. Zylinder.
kw-screw, turbo, oil pressure - all good.
Piston rings defective??
Thank you.
Best regards, Manuel.
Translated on 28-08-2026, 6:01.
Julian
14-11-2004, 11:17
Quote
Valve stem seals need a certain break-in period.
1) What is the warm-up behavior like?
2) Check the compression of the engine when it is at operating temperature.
3) Post the result!
Translated on 28-08-2026, 6:02.
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Carpet Damage: A3 8P1 Documentation
Document A3, 8L, front seat lock damaged
Damaged Threaded Bushing: Repair on Engine Mount?
Passat 3BG Tail Light: Damaged? Parts Available.
TDI Pistons for VW Sharan
Upload
AVR: 5 Identical Pistons - Explained
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.139s
