Audi 80 Coolant Temp: Use Winter Thermostat?
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post28-01-2005, 12:59    Subject: Audi 80 Coolant Temp: Use Winter Thermostat? Quote
Hello everyone.
I recently acquired an Audi 80 B4 from 1994 with a 1Z engine to use as my winter vehicle.
I've noticed that the thermostat isn't closing properly, and the engine only gets warm when driving on the highway. The parts supplier said they have three different options available: 85, 90, and 95 degrees.
"Does anyone know what the normal thermostat temperature is for a 1Z engine? I think it's probably the same for all 1Z models. Is it a good idea to use a 95-degree thermostat for the winter, or is that just unnecessary?"
Translated on 03-11-2026, 10:22.
thom
Post28-01-2005, 18:26    Subject: Audi 80 Coolant Temp: Use Winter Thermostat? Quote
Okay, I also have a 1Z TDI engine from Audi, also manufactured in 1994. I replaced the thermostat about two years ago.
Also meiner geht bis 90°(im Sommer) und dann wird halt geregelt. So richtig Warm wird meiner (im winter)auch nicht bei normaler Fahrweise ca 100km/h, außen schweine kalt und die Heitung schön aufgedreht. Geblow level 3.
It's always been like that. The only thing that helps on short distances is to place something in front of the radiator. Then it will reach 90° and stay there.
Translated on 03-11-2026, 10:23.
Back to top Profile PM Email
Tagessuppe
Post31-01-2005, 9:30    Subject: Audi 80 Coolant Temp: Use Winter Thermostat? Quote
Thank you for your answer, Tom.
That's right. It will never get warm. Yesterday, I tried clamping the hose to the radiator with a clamp, and even after 20 km on the highway at 120 km/h, it didn't get warmer than 95 degrees. The clamp sealed completely, because afterwards the hose was completely cold. I will leave the clamp on during the winter icon_biggrin.gif.
Translated on 03-11-2026, 10:24.
wolfi_b
Post31-01-2005, 9:34    Subject: Audi 80 Coolant Temp: Use Winter Thermostat? Quote
The original temperature is 87°C. According to the AI, this will increase to 88°C in winter, and to 90°C on the highway.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Cooling water temperature Diesel Engine Technology
No new posts Cooling Water Temperature / Water Loss Diesel Engine Technology
No new posts Coolant Temperature Difference: Thermostat vs. Sensor Diesel Engine Technology
No new posts Coolant Temperature 94°C: Why It's Happening Now. Diesel Engine Technology
