Diesel Injectors: V6 2.5L AFB Engine Repair
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Dylofix
Post02-12-2004, 17:10    Subject: Diesel Injectors: V6 2.5L AFB Engine Repair Quote
'There's always a 'diesel-wet' area around two adjacent fuel injectors, which is why my car always smells like diesel after a drive. I've already checked the fuel lines for leaks, but that's not the problem. No fuel leaks when the engine is idling. Does anyone else experience this issue with this engine? Are the fuel injectors defective?'
Translated on 05-08-2026, 4:43.
Diesel_Rudi
Post02-12-2004, 17:25    Subject: Diesel Injectors: V6 2.5L AFB Engine Repair Quote
Is the retaining nut loose? Is the sealing surface of the pressure line misaligned with the nozzle and damaged by tightening?
Regards.
Translated on 05-08-2026, 4:44.
Manuel V
Post02-12-2004, 18:59    Subject: Diesel Injectors: V6 2.5L AFB Engine Repair Quote
Have you ever looked here before?
/viewtopic.php?t=3687&highlight=fuel+injectors+afb
Best regards, Manuel.
Translated on 05-08-2026, 4:45.
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motoröl zum Dieselkraftstoff Diesel Engine Technology
No new posts What is the difference between diesel fuel for trucks and... Diesel Engine Technology
No new posts New fuel injectors for 1Z engine Diesel Engine Technology
No new posts Fuel Injectors VW Golf IV AHU/ALH 90hp Diesel Engine Technology
