Heated Rear Window Interferes with Car Radio
edgar-s
Post16-12-2004, 11:17    Subject: Heated Rear Window Interferes with Car Radio Quote
'I've recently been experiencing the problem described above. Without the heater running, the radio reception is also sometimes very poor. I suspect the antenna amplifier has failed - is there a hidden fuse for it somewhere? (Passat wagon, 1998).'
Translated on 08-10-2026, 11:43.
cetano
Avatar-cetano
Post16-12-2004, 18:57    Subject: Heated Rear Window Interferes with Car Radio Quote
How do the disturbances manifest? (e.g., weak signal, noise, crackling, or...)
It could be a poor connection in the rear window defroster circuit (intermittent high resistance with relatively high current demand), such as a broken wire, especially near the hinge of the tailgate, or corroded connectors, or a faulty switch (less likely).
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 08-10-2026, 11:44.
Back to top Profile PM Email
Post16-12-2004, 19:22    Subject: Heated Rear Window Interferes with Car Radio Quote
In original radios, the antenna amplifier is powered via a so-called "phantom power" supply, which is transmitted through the antenna cable. The only protection for this voltage is a current-limiting resistor located within the radio.
Translated on 08-10-2026, 11:45.
edgar-s
Post17-12-2004, 10:48    Subject: Heated Rear Window Interferes with Car Radio Quote
I don't know what to do anymore.
How can the poor radio reception be explained (i.e., such strong interference that nothing is understandable)?
The rear window defroster is working, but it's extremely annoying.
MWeid
Post17-12-2004, 14:12    Subject: Heated Rear Window Interferes with Car Radio Quote
Hello!
I heard about this problem from an Audi mechanic (I think it was in NU icon_rolleyes.gif), when a heating wire in the rear window defroster is defective! How applicable this is to your Passat: I have no idea?!?
I'm not entirely sure if this only applied to Audi models that had the antenna integrated into the windshield.
Is it possible that a heating element is broken?
Mathias.
Translated on 08-10-2026, 11:46.
garth.brooks
Post17-12-2004, 18:02    Subject: Define "Annoying!": What Does It Mean? Quote
Hi Edgar,
What does 'stört' mean? Is it a scratching or whistling sound? Is the frequency dependent on the engine speed?
Translated on 08-10-2026, 11:47.
edgar-s
Post21-12-2004, 9:34    Subject: Heated Rear Window Interferes with Car Radio Quote
Indeed, a heating element is broken, but I have a roof antenna...
chris11
Karma: +3 / -1   Thank you, like it!
Post21-12-2004, 10:16    Subject: Heated Rear Window Interferes with Car Radio Quote
Even the smallest spark discharge generates a broadband interference signal that extends into the FM radio frequency range. In the early days of "radio transmission," spark transmitters were used.
The malfunction can be caused by a defective heating element, a faulty relay, or a loose connection that is causing interference (which is less common, as these connections usually weld themselves shut).
originate.
Christian.
Translated on 08-10-2026, 11:48.
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B8: System Outage - Bus Disruption? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Defective Rear Window Defroster: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Radio dead On-Board Diagnostics (OBD)
No new posts Radio Beta V Diesel Engine Technology
