Compression OK? Troubleshooting Panzerähnlichem1z in t3
macgyver68
Post22-11-2004, 17:56    Subject: Compression OK? Troubleshooting Panzerähnlichem1z in t3 Quote
I work at a car dealership, but nobody there really knows much about TDI engines.
Are these compression values okay? 1. 22 2. 22 3. 20 4. 21 bar
Does anyone have any other ideas about what I could check without a diagnostic tool?
Error description:
The problem first appeared after running the engine at full throttle in idle mode, then it occurred 3 or 4 times with a warm engine, and now it happens constantly.
- Severe knocking under full throttle and load, blue smoke until warm, power loss, dried oil/diesel residue on piston 4.
already checked/replaced:
zkd screws, zr screws, kw screws, shaft seals, ESD (electrostatic discharge) protection, various hoses.
Greetings and thank you in advance.
Manuel.
Translated on 15-09-2026, 12:57.
donalexo
Post24-11-2004, 19:15    Subject: Compression OK? Troubleshooting Panzerähnlichem1z in t3 Quote
Hello Manuel!
If you want to receive helpful advice in this forum, you need to provide a certain amount of information so that someone can assist you.
Please post the engine code (MKB) and the mileage of the engine. Oops, it says 1Z in the title icon_redface.gif, but it could still be mentioned again in the text.
Well, a loud knocking sound to me suggests incorrect injection timing and/or faulty fuel injectors.
The injector control valve piston in the ESPim area might be stuck in the "early" position. This would then cause a very loud knocking noise from the engine.
The diesel puddle on cylinder 4 smells strongly like a faulty injector, which may even be dripping. Defective injectors can also cause knocking and simultaneously produce blue/black smoke (incomplete combustion).
Depending on the mileage, the blue smoke could also be caused by burnt engine oil, which could originate from the turbocharger, the valve stem seals, or the piston rings.
Since you installed the engine in the bus, the installation angle could also be responsible for the blue smoke.
As you can see, the possibilities are diverse. Therefore, it would be great if you could provide us with as much detailed information as possible about your engine.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 15-09-2026, 12:59.
No new posts VCDS: Troubleshooting Performance Issues Troubleshooting & Guides
No new posts Troubleshooting manual air conditioning system, Volkswage... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Compression: Explained and Optimized Diesel Engine Technology
No new posts A4 B6 2.5 TDI AKE Air Filter Diesel Engine Technology
No new posts AKE V6 TDI: Low Compression Issues Diesel Engine Technology
No new posts TDI 2.5: Compression Problems & Solutions Diesel Engine Technology
