Oil in Coolant: Audi 1Z Engine Problems
tdi racer
Post06-12-2004, 22:27    Subject: Oil in Coolant: Audi 1Z Engine Problems Quote
'A hose that connects the turbocharger to the oil cooler has burst. I've replaced the hose, and I've noticed that everything underneath is covered in oil. The hose itself was also full of oil, and now I'm worried that my oil cooler is also full of oil.'
Surely, this can't be normal, right?
I thought the turbo was mounted on bearings, not on oil.
Is my turbo about to fail?
Translated on 28-09-2026, 3:26.
joergs
Post06-12-2004, 23:36    Subject: Oil in Coolant: Audi 1Z Engine Problems Quote
Try using the search function; you'll find a lot of information on that topic. Whether your oil level is normal or not is something you'll have to decide for yourself. A small tip: the oil doesn't necessarily have to come from the turbo; the crankcase ventilation system could also be a source.
Translated on 28-09-2026, 3:27.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts VW AFN Motor in Audi 80 TDI Diesel Engine Technology
No new posts Audi engine control unit (ECU) AAT - engine On-Board Diagnostics (OBD)
No new posts Audi C4 Engine Control Label File: V6 (12V) AAH On-Board Diagnostics (OBD)
