Elias Guest
04-12-2004, 17:06 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
I have a Golf 4 TDI, manufactured in 1998, with an 81 kW engine (engine code AHF). Recently, while driving on the highway, I noticed that at a speed of 170 km/h, the engine power decreased and the speed was limited to 140 km/h. After that, the car stopped accelerating. I took it to a VW workshop, and they read the error codes, which indicated a 'charge air pressure control differential' error. They told me that the problem could be either the turbocharger itself or the hoses.
Has anyone else experienced this exact error?
Who can help me?
Elias
Translated on 26-10-2026, 14:03.
04-12-2004, 20:29 Subject: Vacuum Leak? VW Golf 4 TDI 81kW |
Elias wrote: | | They read the error code, and it indicated a vacuum leak in the intake manifold. |
Did they invent a new error code, or were they just trying to mess with you?
Or perhaps you've mixed something up?
Okay, I'm ready. Please provide the German text you want me to translate. Gruß Ulf
Translated on 26-10-2026, 14:04.
Profile PM Garage |
Elias Guest
04-12-2004, 23:40 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Okay, so first of all, I spelled it correctly. What I should add is that the error occurs sporadically.
And secondly, I had it done at a VW workshop, and I personally read the report, so please...
Who can help me?
Translated on 26-10-2026, 14:05.
05-12-2004, 1:01 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Elias wrote: | So, first of all, I wrote it correctly, and what I might add is that it still says that the error occurs sporadically...
And secondly, I had it done at a VW workshop, and I read it myself, so please... |
Okay, then I'll sign off here... I don't recognize "low pressure in the intake manifold" as an error message.
But you never stop learning: let's see what the others are writing  . Gruß Ulf
Translated on 26-10-2026, 14:06.
Profile PM Garage |
Yankee Guest
05-12-2004, 15:53 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
@ elias:
I had the same problem, and it was solved by reattaching all the air hoses starting from the air filter. Sometimes they don't fit properly.
In my case, I also had a faulty relay (part number 109). I suspect that it was also responsible for the 'intermittent control difference; error code 575' that I was experiencing. I had the relay replaced by VW for 30 euros including parts - and since then, everything has been quiet.
some links:
/viewtopic.php?t=7156&highlight=
/viewtopic.php?t=4886&highlight=
/viewtopic.php?t=5642&highlight=
Wait until the error occurs again, and have the error codes read by a friendly mechanic.
Translated on 26-10-2026, 14:08.
matthiasTDI96 Profi-Schrauber
05-12-2004, 16:02 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
I would also like to help, but I can only support what Ulf said. Which sensor measures the vacuum in the intake manifold of a TDI engine?
Could it be that there was a difference in pressure in the intake manifold or something similar?
Translated on 26-10-2026, 14:09.
Elias Guest
06-12-2004, 18:53 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Yes, I have to say I phrased it incorrectly. The actual error is called 'intake manifold pressure control differential'... (I've read it again).
Maybe now.
How exactly should I proceed?
Translated on 26-10-2026, 14:10.
06-12-2004, 19:10 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Elias wrote: | | How exactly should I proceed ??? |
1. Read articles on the subject -> common mistakes and VTG loaders.
2. If you understand, please check what's wrong with your engine. Gruß Ulf
Profile PM Garage |
Elias Guest
06-12-2004, 20:35 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Ulf, thank you, but I'm not very familiar with that. You'll have to explain it better to me, e.g.
What is a VTG loader?
Translated on 26-10-2026, 14:11.
06-12-2004, 21:53 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Elias wrote: | | What is a VTG loader? |
Here's a very important tip: The search function is full of useful information for beginners... Gruß Ulf
Profile PM Garage |
Klausel Blaumann
07-12-2004, 2:02 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Ulf, you friend of humanity!
Others might have already given up and closed down a long time ago.
It's something that needs to be said from time to time, otherwise you lose the motivation, right??
And the forum would be poorer because of it.
@Elias: Searching and learning is fun with TDI, but be careful: you might not be able to stop yourself from continuing...
Greetings, Klaus.
Translated on 26-10-2026, 14:12.
07-12-2004, 12:25 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Klausel wrote: | | Others might have already given up and closed down a long time ago. |
I had thought about that too, but sometimes I just slip out of that mindset... Gruß Ulf
Translated on 26-10-2026, 14:13.
Profile PM Garage |
Yankee Guest
07-12-2004, 16:15 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Yes, I must say I phrased it incorrectly; the exact error is 'intake manifold pressure regulation differential'.... (I've read it again).
Maybe now.
I also had this problem. Please check all the thin hoses that run from the air filter for brittleness, proper seating, kinks, etc.
'In my case, a hose was loose... it's been quiet for 12 months now...'
Translated on 26-10-2026, 14:14.
Elias Guest
09-12-2004, 17:41 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
I just went to VW and told them to replace the turbocharger boost valve. They test-installed a new one.
That wasn't it.
Then they thoroughly inspected the hoses and everything was okay.
Next, they replaced the exhaust gas recirculation valve because it was leaking.
The error was still there.
'Measurement block, driving, what's next? Did you find anything there?'
Okay, so I paid 204 euros and picked up the car.
The expert is 100% sure that it's the turbocharger.
Do you have any tips or suggestions on how I can get a turbocharger at a low price?
Translated on 26-10-2026, 14:15.
09-12-2004, 17:50 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
Is the VTG adjustment easy to operate?
Jan. 1Z5 CFHF  / AHB H4D
Translated on 26-10-2026, 14:16.
Elias Guest
09-12-2004, 19:53 Subject: Intake Manifold Pressure: Golf 4 TDI 81kW |
He means.
