27-11-2004, 9:58 Subject: Electric: G3 Wiper Blades Remain Different |
My windshield wipers stop at different positions depending on what I did before.
- If I just briefly touch the wiper control, does it return to the correct end position?
- When I wash the windshield, the wipers move normally and then, after reaching their lowest point, they lift up again about 3 cm.
- With the interval operation (using the programmable 99), the error related to the increasing value also appears.
In addition, it sometimes smells like burning plastic (I suspect this happens when the incorrect end position is reached).
It never smells bad when the wipers end in the correct zero position.
Does anyone have any ideas about this?
The annoying thing is that I have to remove the entire wiper arm assembly if I want to take a look at the engine.
Thank you.
Translated on 18-07-2026, 12:56.
Profile PM Garage |
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
27-11-2004, 11:33 Subject: Electric: G3 Wiper Blades Remain Different |
Hello Martin!
I'm guessing it might be due to stiff wiper shafts in the windshield wiper assembly.
Recently, I also had to replace the entire wiper linkage assembly on my A3 because the wipers were only moving at a snail's pace and with significant jerking across the windshield.
With the new wiper blade attachment, they now glide across the windshield like lightning.
Due to this extreme difficulty in adjusting the wiper arm mounting, my wipers sometimes remained positioned a bit higher than they should have been.
Check this part; you'll soon see whether it's a mechanical or an electrical problem.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 18-07-2026, 12:58.
27-11-2004, 11:54 Subject: Subject: Re: Electric - G3 windshield wipers remain in different positions |
dieselmartin wrote: | - If I just briefly activate the wiper, it returns to its correct end position.
It never smells bad when the wipers end in the correct zero position. |
If the wipers continue to move slowly or quickly even after being turned off for an extended period, I believe it's due to the "timing" of the interval relay.
This is responsible for the interval function (you might not believe it  ), and for the post-wash wiping; in other operating modes, the motor switches off automatically due to the "UT switch".
Perhaps the smell of ozone is coming from the relay  .
Translated on 18-07-2026, 13:00.
Profile PM Garage |
27-11-2004, 12:09 Subject: Electric: G3 Wiper Blades Remain Different |
I also suspected the relay and had already checked it.
 It doesn't smell like Amperes.
Could it be that the relay used to switch off also utilizes the UT contact of the motor?
And if the engine runs for too long, it might start to overheat and smoke because the "run-on" contact only provides a minimal amount of current.
I still have a size 19 relay at home; I'll try it out when I get back.
I naturally just gave away the backup-99er  .
That stupid motor costs 100 euros – I was actually hoping to avoid that expense.
Translated on 18-07-2026, 13:03.
Profile PM Garage |
27-11-2004, 12:18 Subject: Electric: G3 Wiper Blades Remain Different |
dieselmartin wrote: | Could it be that the relay is used not only to switch off, but also utilizes the UT contact of the motor?
And if the engine has run for a bit too long, it might start to smolder because the "run-on" contact only provides a slight amount of "contact." |
"In my opinion, no, because the UT switch is a changeover contact: either the motor is connected to the power supply, or (on both sides) it's connected to ground."
But the power supply and mass should not be short-circuited. If they are, a fuse would blow or at least the light would flicker briefly  .
Quote: | | Could it be that the relay is used not only to switch off, but also utilizes the UT contact of the motor? |
In summary, yes. And if it doesn't respond to this or responds late, the motor may sometimes stop just before the end of the cycle – if the voltage for the next wiping cycle hasn't been automatically switched on again yet.
Translated on 18-07-2026, 13:05.
Profile PM Garage |
27-11-2004, 15:28 Subject: Electric: G3 Wiper Blades Remain Different |
Okay.
Okay, so I hope this thing doesn't break down before Monday, and then I'll check it with the 19mm wrench afterwards.
If nothing else works, I'll have to install a new engine next week "blindly," meaning without knowing exactly what's wrong.
Because I'm not going to Spain with a squealing windshield wiper motor!
Translated on 18-07-2026, 13:07.
Profile PM Garage |
Henrik Guest
28-11-2004, 10:05 Subject: Electric: G3 Wiper Blades Remain Different |
It was the windshield wiper lever for me...
Symptoms I'm experiencing:
The wipers would only move up 3-5 cm when used in intermittent mode, and at very high speeds, one of the wipers would even complete a full rotation.
It was also difficult to activate the single-wipe function; you almost had to search for the right spot to touch.
The normal continuous wiping function worked without any problems, and I was also able to correctly return everything to its starting position with it.
I'm not sure how the interval cycle relates to the lever, but whatever it was, it worked after the change.
Translated on 18-07-2026, 13:08.
Jockel Blaumann
Joined: 03/14/2004 Posts: 249 Karma: +15 / -1 Location: 84478 Waldkraiburg
29-11-2004, 10:33 Subject: Electric: G3 Wiper Blades Remain Different |
Enjoy your meal! / Have a good lunch!
I had something similar in my second-generation Golf; it was always located near the engine, and it's the same type of part as you find in the third-generation Golf.
If you remove the engine and take off the plastic cover, you'll see the friction surfaces; mine had regularly burnt spots on them.
If your windshield wiper arm is broken, you probably need a replacement, and I might have one for you; I'll take a look.
whether it still moves easily.
Hi, Jockel.
"Neu": Bora Variant, ASV
Translated on 18-07-2026, 13:10.
Profile PM Email |
Schneemann Blaumann
Joined: 08/09/2003 Posts: 78 Karma: +2 / -0 Location: Wissen
29-11-2004, 16:44 Subject: If I could chime in... |
Here's my two cents: I'm experiencing the same problem – the windshield washer fluid system is stuck and there's a strong electrical smell. Additionally, I sometimes notice a very faint smoke coming from the steering column area.
Result of the investigation: The circuit breaker occasionally gets stuck and does not return to the "off" position correctly when switched off.
A little contact cleaner to clean the mechanism was needed, and it worked much better after that.
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 18-07-2026, 13:11.
12-12-2004, 20:14 Subject: Electric: G3 Wiper Blades Remain Different |
Sure.
I'm now quite sure that it's the switch.
Being as reckless as I am, I drove to Spain in the condition described above.
Last night near Lyon, something smelled so bad that it was really unpleasant.
If I clean the toilet regularly using interval cleaning, it doesn't smell bad.
Thank you for the tips.
Now I have a good excuse to buy a shifter with MFA buttons  .
Translated on 18-07-2026, 13:12.
Profile PM Garage |
17-01-2005, 17:12 Subject: Electric: G3 Wiper Blades Remain Different |
Okay,
The windshield wiper lever (switch) has been replaced (€17), and everything is working fine again.
Thanks for the tips; of course, Volkswagen had said that I should replace the engine!
It is the standard lever, and one with MFA would have cost 47 EUR  .
Translated on 18-07-2026, 13:14.
Profile PM Garage |
