Volvo V70 TDI with Audi/AEL wave-like acceleration
thrurl
Post14-12-2004, 18:27    Subject: Volvo V70 TDI with Audi/AEL wave-like acceleration Quote
Hello everyone,
I drive a V70 TDI with a 5-cylinder Audi engine, model AEL, 140 horsepower, with 195,000 km on the odometer, first registered in April 2000.
For the past year, the car has been experiencing a gradual loss of power.
Over 150, all very tough. Very poor performance in hot summer weather, especially below that temperature.
2300. Wave-like acceleration on the highway, occurring every 2 seconds.
The Volvo control unit didn't yield any useful data.
Volvo suggested replacing the injector nozzle, then the turbocharger, then the pump, etc.
Of course, I would have to pay for the parts... there's really nothing more to say about that.
After doing some research here on the forum, I replaced the mass airflow sensor (MAF), and it was a successful fix. Performance is significantly better, with noticeable power increase from 2000 RPM. (Bosch 0280218045, 63 Euros).
However, the 'wavy' power delivery in 5th gear is still slightly noticeable, although it is significantly better.
Would replacing the magnetic valve that controls the pressure sensor of the turbocharger be the next step here? It's from Pierburg, part number 7 222 40 01, and there are two other numbers on it:
98T335, and 127 5924.
Does anyone know if I can also get this part from Audi?
Thank you in advance for any tips.
Thomas.
P.S. Otherwise, the car is running quite well, with a fuel consumption of 5.5-6.5 L/100 km on long distances.
Post14-12-2004, 20:28    Subject: Re: Volvo V70 TDI with Audi/AEL - Wave-like acceleration Quote
However, the "wavy" power delivery in 5th gear is still slightly noticeable, although it is significantly better.
Would replacing the magnetic valve that controls the pressure sensor of the charger be the next step here?
Before making the next disbursement of funds without a clear purpose, I would first check whether the boost pressure actually deviates from the target value -> install a LDA icon_wink.gif.
Don't ask me where to get Volvo specifications... maybe from the friendly moose?
Andi aus dem Ösiland
Post14-12-2004, 23:48    Subject: Volvo V70 TDI with Audi/AEL wave-like acceleration Quote
Hello!
Here you can find the expected data for the AEL.
http://www.dieselschrauber.de/Solldaten_5_Zylinder_VE.html
The turbo pressure should be 1920 mbar!
Andi.
No new posts Beschleunigung endet vor Vmax General Tips
No new posts TDI Wave Acceleration: Causes and Solutions Technical Articles
No new posts Document: A4, Emergency Procedure After Strong Acceleration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leichtes Ruckeln bzw. wellenförmige Beschleunigung Diesel Engine Technology
No new posts Wave Acceleration on 2.5L V6 6Zyl Engine Diesel Engine Technology
No new posts Volvo V70 with Audi AEL 2.5TDI - No Power Diesel Engine Technology
No new posts Extremes Ruckeln bei 2500 - 3000 Upm bei 2.5 TDI Audi/Volvo Diesel Engine Technology
