Roadrunner505 Blaumann
14-12-2004, 11:06 Subject: Boost Pressure Sensors: Parts & Accessories |
Since my turbocharger is working, my current project is to check the transmission of the turbocharger's power to the engine control unit. It seems that this transmission is not optimal, so the control unit doesn't register that there is enough air pressure available, and therefore doesn't release enough fuel.
"That's probably related to the vacuum hose that runs from the turbo to the engine control unit, right? Otherwise, I've also heard of a solenoid valve that controls something. Which components, from the turbo to the engine control unit, could be damaged if there's apparently a faulty transmission, and how would you test them?"
Translated on 10-10-2026, 18:32.
14-12-2004, 11:41 Subject: Boost Pressure Sensors: Parts & Accessories |
Hi there.
Since the "transmission" functions in two different ways, you first need to tell me what type of engine you have.
No hoses should connect from the turbocharger to the STG (Selective Catalytic Reduction system), especially no hoses that carry vacuum.
On the 1Z, AFN, AHU, and ALE engines, a pressure hose runs from the intake manifold to the control unit (STG).
The newer models (starting with the Golf 4) have a pressure sensor in the coolant reservoir, which then transmits the information electrically to the control unit.
How do you know if there is enough pressure and if too little material is being released?
Do you have logs?
m; Transparency, Teamwork
Translated on 10-10-2026, 18:34.
Profile PM Garage |
wolfi_b Profi-Schrauber
14-12-2004, 11:46 Subject: Boost Pressure Sensors: Parts & Accessories |
@ dieselmartin
Do you not recognize him anymore  ?
/viewtopic.php?t=7784&highlight=
@Roadrunner
Why don't you continue the discussion in the original thread? 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 10-10-2026, 18:35.
14-12-2004, 12:32 Subject: Boost Pressure Sensors: Parts & Accessories |
Oops, I totally forgot.
A week without being online, and everything is already deleted.
SIGN
Translated on 10-10-2026, 18:36.
Profile PM Garage |
14-12-2004, 12:41 Subject: Boost Pressure Sensors: Parts & Accessories |
Okay, I must have gotten that wrong.
Okay, so it's probably a pressure hose then. Sorry for not mentioning the engine again. It's a 1996 Passat with a 1Z engine.
@Wolfi_b
I started a new thread because you all seemed bored with the other one, and I didn't want to continue the discussion about whether the tuner is a fraud or not. After draining the condensate from the aforementioned hose, it produces at least 100 horsepower (according to the DZR).
As I mentioned, the moisture got in due to a faulty hose, and after the pressure hose was replaced, it couldn't escape anymore.
The turbo was checked (mechanically) and, strangely, it's consistently producing 1.5 bar. It seems there's definitely something wrong with the control system.
Translated on 10-10-2026, 18:37.
14-12-2004, 12:45 Subject: Boost Pressure Sensors: Parts & Accessories |
Huh??
"Permanent" cannot be correct because the logs in the old thread show values of 1300-2000 mBar, which corresponds to a boost pressure of 0.3 to 1 bar.
Maybe try replacing the N75 valve.
http://people.freenet.de/golf-schrauber/Magnetventil.jpg
Near the brake booster, on the Passat.
Translated on 10-10-2026, 18:39.
Profile PM Garage |
14-12-2004, 12:50 Subject: Boost Pressure Sensors: Parts & Accessories |
Yes, a solenoid valve is definitely a good option.
The issue with the log might actually be whether the engine control unit (which is being read) is truly receiving information about what's happening mechanically with the turbocharger, or whether the values are being distorted by the water and potentially damaged components.
15-12-2004, 9:07 Subject: Boost Pressure Sensors: Parts & Accessories |
Okay, I've created a new log.
It's now clear that while the injection quantity has increased, it still falls short of the target values in the last section.
"Since the relevant components like the turbocharger, mass airflow sensor, and similar parts are in good condition, and the improvement in performance corresponded to the previously measured values after water was drained from the overpressure hose connecting the turbocharger to the control unit (STG), VW now suspects that the sensor responsible for interpreting the turbocharger data is faulty and recommends trying it with a different STG."
The solenoid valve seems to be working correctly, as the target and actual boost pressures are aligning. However, it remains unclear why a mechanical measurement of the turbocharger consistently showed a reading of 1.5 bar.
Should I continue down the path with the replacement ECU, or does anyone, perhaps referring to this new information, the new log files, or in connection with the last thread /viewtopic.php?t=7784, have a different idea?
 [/url]
Translated on 10-10-2026, 18:41.
15-12-2004, 9:35 Subject: Boost Pressure Sensors: Parts & Accessories |
Unbelievable
The injection amounts for torque and smoke reduction have increased by 30%!
The target value for the boost pressure has also increased by approximately 0.13 bar!
Sure, there's more power available now.
Was new software installed? Perhaps without you being informed?
However, the smoke limit still restricts the fuel injection amount, even though the mass airflow sensor (MAF) value is normal...  1993 Audi 80 B4 1Z
Translated on 10-10-2026, 18:43.
15-12-2004, 10:55 Subject: Boost Pressure Sensors: Parts & Accessories |
I'm starting to believe anything these days... But if there really is something shady going on, why would OBD-Tuning spend a whole day looking at the car, manually checking all the values, introduce a source of error, and then mess around with the software, without arbitrarily increasing the emission limits and pretending everything is fine?
If they had wanted to trick me with some kind of false information, they could have simply raised the limits, and I wouldn't have said anything, right?
Furthermore, I don't believe that a company whose products are tested by six different providers in "Auto-BILD" (and with good results) would need to cut corners. It simply doesn't make sense. They could just do it properly.
Is the smoke limit solely dependent on the LMM values, or can other parameters also push the limit downwards?
And just to reiterate: If they never had to manually raise the limit to cover up a mistake, then why wouldn't they have done so?
Translated on 10-10-2026, 18:44.
15-12-2004, 11:07 Subject: Boost Pressure Sensors: Parts & Accessories |
@ Road
Why are you putting so much thought into why the "tuning" company should or shouldn't have done certain things?
For me (and I can only speak for myself), it is completely irrelevant in this situation what they think or believe.
The result and the effort (money and time) that I invest are of interest to me.
I don't care which blast furnace was used, or under what labor agreements, to produce the iron that went into my Golf – if the car rusts after 2 years, I'll go to my dealer and give him a hard time. It's then *his* responsibility to resolve the issue *to my satisfaction*. How he does it (whether that means he has less money for repainting the showroom) is completely irrelevant to me!
You now have proof that your engine control unit was tampered with – whether the technician was drunk or the company was trying to rip you off, it doesn't matter, they messed something up.
Therefore, I wish you continued success in your business, with your unwavering faith in God – I just can't understand you.
Technically speaking, I can't understand the software they're using, because ideally, the car's performance should be regulated based on the driver's input and the amount of torque. Your mass airflow sensor (MAF) is definitely still working well, with over 800 mg at 4000 RPM - it's not the problem.
Since the company also modified the Russian zone, any persistent "triggering" of the Russian border can only be due to changes in their zone definitions.
In my opinion, this is purely a software issue.
Translated on 10-10-2026, 18:47.
Profile PM Garage |
15-12-2004, 11:25 Subject: Boost Pressure Sensors: Parts & Accessories |
I completely agree with Martin.
The logs only suggest that the software was modified.
Roadrunner505 wrote: | | Is the smoke limit solely dependent on the LMM values, or can other parameters also push the limit downwards? |
Mainly based on the LMM value and the engine speed.
I'm also not familiar with any other parameters, but it might be related to injection timing, temperatures, etc.
I can't imagine that they could have such a strong effect, besides, you've already checked the measurements for plausibility.
Therefore, I can only quote Martin:
dieselmartin wrote: | | In my opinion, this is purely a software problem. | 1993 Audi 80 B4 1Z
Translated on 10-10-2026, 18:50.
joergs Guest
15-12-2004, 12:03 Subject: Boost Pressure Sensors: Parts & Accessories |
I've only been reading your posts so far. However, a question arises: Why are you defending this company? Is this an advertisement? If so, it would be a very, very... questionable one! The measurements speak for themselves. There's no hardware problem. In my opinion, it's the software.
Translated on 10-10-2026, 18:52.
15-12-2004, 12:33 Subject: Boost Pressure Sensors: Parts & Accessories |
Okay, I'm starting to get frustrated. I'm getting different opinions from everyone. How am I supposed to know what's right? I'm going to try going to the Auto Bild editorial office here at the company. I've already spoken to an editor there. Maybe they have contact with a tuner who, at their suggestion, could provide a professional and unbiased assessment, and, if necessary, prove the facts.
If it turns out that something is wrong with the matter, you can read the whole story in the next issue...
Thomas K. Guest
15-12-2004, 20:19 Subject: Boost Pressure Sensors: Parts & Accessories |
I wish I had your perseverance and naivete.
'Have them revert the car to its original configuration and give you your money back. I'd be interested to see how they react.'
Meanwhile, several specialists here have told you the same thing – 'the chip is junk' – and you still don't believe it.
Translated on 10-10-2026, 18:53.
16-12-2004, 16:58 Subject: Boost Pressure Sensors: Parts & Accessories |
The situation is, of course, somewhat ambiguous.
The tuner sold me a chip, not a modified car.
If the chip is working correctly, the seller has fulfilled their contract. It's not their fault if the conditions for the service are not met.
Comparison: Just like you can't blame the retailer if the USB port on your computer is defective after you buy a joystick.
BUT: If the software is really terrible, then they are liable  .
But how can I prove it? I initially contacted another, larger tuning company through the editorial team to see if they would look into it. Maybe I can gather evidence of shoddy workmanship and be better prepared for a legal dispute...?
Okay, I really don't mean to be rude, but I'm not going to immediately dismiss something just because of your opinions. I'm taking your advice into consideration in order to provide solid evidence.
I'm also having the whole thing checked, with the note that I want proof that someone has tampered with it afterwards, etc.
Translated on 10-10-2026, 18:55.
