Motor Upgrade: 130 HP -> 160 HP?
Go to page: 1, 2, 3  Next
Post11-12-2004, 10:33    Subject: Motor Upgrade: 130 HP -> 160 HP? Quote
I've been going through the files and compared the BPX (Ibiza Cupra 160 PS) with the ASZ and ARL.
Result (for MJ 2003 - 2005):
1. The BPX cylinder block (038 103 101 AB) is the same as the one used in the ASZ and ARL engines in the Golf 4, Leon, and Toledo.
The ASZs in Ibiza and Polo have different blocks, and I don't understand why.
But the Zyl-head is actually the same again.
2. The BPX water pump conforms to the ARL standard, while ASZs have different pumps.
3. In addition, there are different chargers (the ones from ARL and BPX are not even the same), as well as external parts like LLK, etc.
4. Otherwise, all the parts that transmit power are identical in the ASZ ARL and BPX (piston, crankshaft, etc.), the same applies to the engine control (camshaft, timing belt, etc.), the gearboxes, and even the oil pump and oil spray nozzles for cooling the pistons.
Means, in plain language:
Basically, all you need to do is replace the water pump and the turbocharger, and then a Golf 4 ASZ will have the hardware of an ARL. The software is irrelevant here.
But what significance/consequences do the other ASZ cylinder head blocks have for the Polo (038 103 101 AJ) and Ibiza (038 103 101 AG)?
Could they become a weakness (strength, cooling water channels . . .), if you upgrade the rest to BPX?
Frankly, the idea of a "Polo Cupra" with a long wheelbase seems quite appealing to me... icon_rolleyes.gif
Post12-12-2004, 12:16    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Ulf, kann es sein das der Block eine andere Nummer hat, weid die Aufnahmen für die Nebenagregate doch sicher anders sind. Haben Ibiza und Polo 9N nicht z.B. eine elektrisch angetriebene Servolenkung wo hingegen die Golf IV Plattform noch mit der hydraulischen Anlage vom Motor direkt angetrieben herumfährt? Wäre das eine Möglichkeit? Das Material ist doch sicher das Selbe.
Die Turbolader unterscheiden sich doch nur durch den Endbuchstaben ( ist doch bei beiden der Typ GT1749V ), beim ARL das G beim ASZ das F oder bin ich falsch informiert. Weißt du was dort geändert wurde? Sind die Turbinenschaufeln dort anders angeordnet? vom Querschnitt sind doch beide Lader identisch.
Post12-12-2004, 13:14    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Das mit der Lenkung stimmt, das mit dem Material liegt nahe.
Aber auch der Ibiza Cupra dürfte die Elektrolenkung haben und bekam trotzdem den ARL-Block . . .
Verdichtereingang und Abgasabgang haben die gleichen Flanschmaße, soweit hast Du recht.
Trotzdem muß der ARL-Verdichter irgendwie auf höheren Massentrom optimiert sein, denn sonst hätte man ja den ASZ-Lader nehmen können icon_wink.gif
Post12-12-2004, 13:27    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Ok das mit dem CUPRA habe ic nicht bedacht. Nun ja ich dachte ja auch das der Lader verschieden ist, das liegt ja nahe. Nur hätte mich interessiert was genau da anders ist, wie gesagt ich kenne als einzigen Unterschied, das G anstelle das F. Wahrscheinlich schaufelt er etwas mehr Masse da ja auch die Ladeluftstrecke etwas "üppiger" ist.
EIne Frage hab ich noch wenn du dich gerade damit beschäftigst. Hat der ARL eine andere ( dickere ) ZKD, da er laut meinen Unterlagen ( zugegeben VW Bordbuch ) eine um 0,5 geringere Verdichtung aufweist.
Post12-12-2004, 14:57    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Tja . . . Kolben, Pleuel, KW, ZK und die 3 ZKD (verschiedene Dicken) sind identisch.
Wenn allerdings der ARL-Zyl.block eine Idee höher sein sollte als beim ASZ, ließe sich damit natürlich auch eine geringere Verdichtung erreichen . . . icon_question.gif
EDIT (nach verpätetem Nachdenken icon_redface.gif )
Im Golf 4 und Leon / Toledo haben ASZ und ARL auch den gleichen Zyl.Block.
Das spricht wieder für die gleiche Bauhöhe, denn sonst hätte der ASZ im Golf und Leon eine geringere Verdichtung als im Ibi / Polo.
Hat vielleicht jemand Zugriff auf Reparaturanleitungen für ASZ und ARL?
-> Bei unterschiedlicher Bauhöhe müßten auch die Kolbenüberstands-Referenzmaße für die ZKD-Auswahl verschieden sein . . .
Klima96
Karma: +6 / -1   Thank you, like it!
Post12-12-2004, 19:27    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Was ist den an der Ladeluftstrecke unterschiedlich ???
Beim Auktionshaus wird mit 150 PS TDI Ladern geworben um den 130 PS zu tunen .
Würde also der Lader Hardwaretechnisch passen aber nichts bringen !?
Golf 4 TDI PD 96 KW 6 Gang ASZ ERF
Jetzt 114 Kw nach *** Chip
Post12-12-2004, 19:35    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
WSie geschrieben sind die Lader fast die gleichen. Wahrscheinlich ist da nur etwas an der Turbinengeometrie geändert. Ob der Tausch des Laders was bewirkt ist fraglich ohne eine Anpassung der Elektronik.
Kann ich mir vorstellen, muss aber nicht so sein.
SD16
Post12-12-2004, 19:39    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]Es ist anders :
Turbolader
Ladedluftkühler und Schläuche!
PD Elemente
STG
Abgasanlage
Luftfilter mit Luftführung
Post12-12-2004, 21:35    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
SD16 wrote:
Es ist anders :
Welche Motoren / Fahrzeuge hast Du hier verglichen?
PD Elemente
ASZ, ARL und BPX haben die gleichen: 038 130 073 AL
Abgasanlage
ASZ im Polo / Ibiza und der BPX haben zumindest das gleiche Kat-Stück direkt hinter dem Lader.
Und der Kat ist AFAIK üblicherweise das bestimmende Teil (im Sinne des schwächsten Gliedes) für den Durchsatz der Abgasanlage . . .
Klima96
Post12-12-2004, 21:46    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Also meines wissens nach ist der LLK auf jeden Fall unterschiedlich beim ASZ und ARL .
Beim ARL müßte es ein flacherer und größerer sein . Dem zu Folge ist die Verrorhung
auch anders als beim ASZ .
Wenn die Anschlüsse der beiden Lader ASZ und ARL gleich sind -
Was würde passieren wenn einfach der ARL Lader in den ASZ gebaut würde ???
Ohne im STG etwas zu ändern ?
Würde der LLK vom ASZ es schwer haben die mehr umgesetzte Luft beim ARL Lader
runter zu kühlen ?
SD16
Post12-12-2004, 22:31    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]Kenne den 160PS TDI nur im Seat Cupra!
Denke aber ist bei VW gleisch.
Post13-12-2004, 8:00    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Hab ich ja ganz oben schon geschrieben:
Hinzu kommen jeweils andere Lader . . . und externe Teile wie LLK usw.
runter zu kühlen ?
Wieso mehr umgesetzte Luft beim ARL Lader?
Dazu müßte erstmal der Ladedruck höher geregelt werden, aber ohne Änderung des STG?
Der ARL Lader alleine könnte höchstens ein größeres Turboloch verursachen.
Jay_Dee
Post13-12-2004, 10:17    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]Der ASZ- und ARL Lader haben unterschiedliche Anschlusstuecke.
Die Ladeluftstrecke ist ja auch anders.
ASZ= LLK im Radhaus
ARL= LLK vor dem Wasserkuehler
Mein Tuner meinte, dass es aber moeglich sei den ARL Lader im ASZ zu verbauen, man muesste nur mit den teuren Schlaeuchen tricksen.
Nochmal zu den Unterschieden:
Hat der ARL im Vergleich zum ASZ nicht auch staerkere Lagerschalen und andere Pleuel?
Post13-12-2004, 10:52    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Nee, ab Mj. 2003 alles gleich.
Jay_Dee
Post13-12-2004, 12:02    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]Dann hat der ASZ ab diesem Baujahr also die verstaerkten Teile des ARL erhalten, ja?
Post13-12-2004, 12:19    Subject: Motor Upgrade: 130 HP -> 160 HP? Translating...
[Translating...]
Ja, Ulf hat da schon richtig recherchiert icon_wink.gif .
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Übersicht AFB-Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DSG Tronic Upgrade Transmission, Chassis, Body & Interior
No new posts Fehler beim Firmware Upgrade On-Board Diagnostics (OBD)
No new posts VCDS Lizenz Upgrade, FIN löschen On-Board Diagnostics (OBD)
No new posts ASZ-Upgrade auf EU4 "grün ohne DPF"? Diesel Engine Technology
