GRA Behavior in ASZ (96 kW PD) - What's Normal?
pschaefer
Post23-07-2003, 19:57    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
Hello!
"Regarding my Golf IV with a 96kW ASZ engine and automatic transmission, I find..."
The GRA is really awful when accelerating.
If you continuously press the "+" button and eventually...
"When you release it, there's a strong jolt! Can't this thing just 'ease off the gas'?"
Translated on 28-09-2026, 9:21.
Post24-07-2003, 18:11    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
Hi, our cars seem to be the same except for the automatic transmission. I also have that "jerking" issue, which bothered me for a long time, but it seems like that's how it's supposed to be. I once read somewhere that it works with 1005 when accelerating with the cruise control. However, I can't reproduce the jerking if I suddenly release the gas pedal while accelerating. Basically, it's true that it immediately reduces power to maintain the set speed. Imagine if it gradually reduced the gas...
Okay, I'm assuming that's normal... at least for VW. It's smoother with Mercedes.
Translated on 28-09-2026, 9:22.
Gremlin
Post24-07-2003, 19:21    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
Unfortunately, my ALH with automatic transmission does the same thing.
It seems that the GRA is bypassing the frame rate stabilization.
I see it as a software bug.
CU Gremlin.
Translated on 28-09-2026, 9:24.
pschaefer
Post24-07-2003, 21:11    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
I see it as a software bug...
I see it that way too. When I'm traveling alone, I find that...
It's just annoying, but the problem is that passengers.
...will probably look at you in a very strange way someday...
Well, software generally has the advantage of changing something.
to be able to... Does anyone have the source code?
A C compiler is available icon_wink.gif icon_wink.gif icon_wink.gif.
Translated on 28-09-2026, 9:25.
ckone
Post21-01-2005, 12:08    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
I'm reviving this old thread instead of starting a new one.
I'm experiencing the same problem with my AXR, but mine doesn't have an automatic transmission. Is there a solution for this yet?
Translated on 28-09-2026, 9:26.
Bee
Post21-01-2005, 12:57    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
The GRA button suddenly switches from 100% to a specific gas value. This definitely cannot be controlled by the pedal.
I see that as not very disruptive.
'Micha'
Karma: +442 / -0   Thank you, like it!
Post21-01-2005, 15:36    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
There probably won't be a real solution for this, as VW likely doesn't consider the problem important enough to adjust the TCU software in one of the next updates.
But there's at least a workaround: Use the gas pedal instead of the "+" button to accelerate, and simply press "Set" when you reach the desired speed... Or is your right foot completely numb when you drive with GRA icon_wink.gif?
Initially, I was also disappointed with the GRA's inadequate acceleration capabilities, but after about a year, I didn't notice it anymore...
Sure.
Here is the translation of the text from German to English:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used as a verb, meaning "to gust" or "to blow."
Here are some examples of how the word "Guste" can be used:
* "Der Guste wehte stark." (The gust of wind blew strongly.)
* "Der Wind gustete." (The wind gusted.)
* "Ich gustete." (I gusted.)
I hope this helps!
Translated on 28-09-2026, 9:28.
Post22-01-2005, 10:57    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
...are you talking about the jerking, or does your scooter accelerate poorly when you press the "+" button? We were talking about 100% power when you touch the "+" button. Mine also has the jerking, but it doesn't bother me anymore, because it accelerates extremely when you press it... so my foot is "completely relieved" on longer distances.
Translated on 28-09-2026, 9:29.
golfschrauber1981
Post22-01-2005, 21:59    Subject: GRA Behavior in ASZ (96 kW PD) - What's Normal? Quote
There probably won't be a real solution for it, since VW likely doesn't consider the problem important enough to adjust the STG software in one of the next updates.
This problem has existed with VW for ages. My G3 V does the same thing.
I highly doubt VW will change anything. Why would they? The car has been sold, and they've made their money. So, they'll likely ignore this issue, just like other, more serious flaws.
Translated on 28-09-2026, 9:30.
No new posts P2452 - Diesel Particulate Filter Pressure Sensor 'A', Ma... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0404 - Exhaust Gas Recirculation (EGR) Control Circuit M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Behavior in ALH 66kW Engines Diesel Engine Technology
No new posts Strange behavior of the air conditioner Transmission, Chassis, Body & Interior
No new posts Strange behavior with LD-control valve On-Board Diagnostics (OBD)
No new posts AGR Deactivated: Behavior Unchanged? Diesel Engine Technology
