Webasto Spare Parts
christians
Post26-12-2004, 16:21    Subject: Webasto Spare Parts Quote
I need a new combustion chamber (110 Euros) for my auxiliary heater because a glow plug (17 Euros) was identified as defective. Still, it's better than having to replace a defective felt material (5 Euros) icon_evil.gif.
Are these spare parts available anywhere else besides auctions, and specifically, are they cheaper than at Bosch service centers?
Gruß Christian
Translated on 10-09-2026, 17:02.
Gremlin
Post26-12-2004, 19:21    Subject: Webasto Spare Parts Quote
Are spark plugs no longer sold individually?
Please provide the text you would like me to translate from German to English.
CU Gremlin.
Translated on 10-09-2026, 17:03.
christians
Post26-12-2004, 21:05    Subject: Webasto Spare Parts Quote
Unfortunately, according to other posts and also the schematic diagram on the DataTop CD, it is not compatible with the Thermotop E.
Gruß Christian
Translated on 10-09-2026, 17:04.
Jan03
2010 Volkswagen Polo
Post27-12-2004, 18:29    Subject: Webasto Spare Parts Quote
I had the same problem and couldn't find a cheaper source. You can often find new combustion chambers on E**y for under 50 euros. I bought one there recently, and it works perfectly.
/Jan
christians
Post28-12-2004, 20:04    Subject: Webasto Spare Parts Quote
Okay,
The new combustion chamber has arrived. The glow plug could certainly be replaced individually if one could obtain it separately. However, it's not a standard glow plug; it's a black square with a round white ceramic base.
If anyone has any idea where to find something like this or what Webasto installed, please let me know.
Gruß Christian
Translated on 10-09-2026, 17:05.
christians
Post29-12-2004, 22:03    Subject: Webasto Spare Parts Quote
I have now replaced the combustion chamber.
I don't need a new felt-tip pen after all, because the felt itself is also looking worn out.
While it hasn't crumbled, it's partially carbonized. There's also a significant amount of oil residue and/or ash in the combustion chamber and the heat exchanger.
Is this normal after a little over 3 years, or could the 5% biodiesel blend be the culprit?
Gruß Christian
Translated on 10-09-2026, 17:06.
Jan03
Post29-12-2004, 23:52    Subject: Webasto Spare Parts Quote
"With my ThermoTop C, I could clearly see the presence of paraffin deposits after just one year, and this without using biodiesel (which isn't available where I am). However, the deposits were limited to the combustion chamber; the rest of the system was clean. Do you have a filter installed before the dosing pump?"
/Jan
Translated on 10-09-2026, 17:07.
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
This topic is locked, you cannot edit or reply. VCDS Parts: Alternatives & Replacements On-Board Diagnostics (OBD)
No new posts Timing Belt Kit for PD AJM 2001 Diesel Engine Technology
No new posts Ersatzteile fßr Eberspächer Standheizung gesucht Transmission, Chassis, Body & Interior
No new posts Webasto STH Diagnosis: Troubleshooting Guide Transmission, Chassis, Body & Interior
