ZKD Replacement: How to Change It Easily
bernie123
Post25-12-2004, 15:46    Subject: ZKD Replacement: How to Change It Easily Quote
Hello forum,
I'm new to this forum and already have a question: I have a head gasket replacement coming up.
(Volkswagen Golf 2 D, manufactured in 1989, 190,000 km) What other measures should be taken in this case?
hello
Bernie.
Translated on 24-09-2026, 4:24.
Jockel
Karma: +15 / -1   Thank you, like it!
Post25-12-2004, 19:37    Subject: ZKD Replacement: How to Change It Easily Quote
Enjoy your meal!
Why is it broken?
I would replace the thermostats, and possibly the radiator hoses as well, if they seem porous.
You could also have the fuel injectors checked or cleaned, given the mileage.
You can get new ones; for example, you can find them at dieselsend.de.
Hi, Jockel.
"Neu": Bora Variant, ASV
Translated on 24-09-2026, 4:25.
Back to top Profile PM Email
Gremlin
Post25-12-2004, 19:46    Subject: ZKD Replacement: How to Change It Easily Quote
Please examine the head very carefully, paying particular attention to any cracks between the valves or between the valve and the combustion chamber.
CU Gremlin.
Translated on 24-09-2026, 4:26.
wolfi_b
Post25-12-2004, 23:10    Subject: ZKD Replacement: How to Change It Easily Quote
If your ZKD (presumably a type of component) failed due to overheating, be sure to also check the flatness of the head.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
bernie123
Post26-12-2004, 13:26    Subject: ZKD Replacement: How to Change It Easily Quote
Hello forum,
The ZKD (likely referring to a specific component or device) failed due to overheating (producing white smoke). Unfortunately, this happened this morning.
Started briefly, starter immediately seized up ---> Could be water damage? Is it possible to check for water damage?
Hello.
Bernie.
Translated on 24-09-2026, 4:27.
Gremlin
Post26-12-2004, 14:32    Subject: ZKD Replacement: How to Change It Easily Quote
argh...
Hopefully, nothing is bent or damaged.
Remove the glow plugs or fuel injectors and turn them manually.
Then you'll see if water is coming out, and if it is, please quickly lower your head and lie down on something dry.
CU Gremlin.
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts ZR change in PDs? Diesel Engine Technology
No new posts ZR - Change at 1.4 PD Diesel Engine Technology
No new posts ZMS switch to ASZ with ERF Transmission, Chassis, Body & Interior
No new posts ZR Replacement: Is €440 a Fair Price? Diesel Engine Technology
