Octavia_4x4 Schrauber
09-09-2010, 14:47 Subject: VW MFD Rotary Knobs: Source & Buy Now |
Currently, a friend is experiencing an issue with their MFD (the first-generation color navigation system from the Golf IV and similar models) where the rubber coverings on both rotary knobs have detached and disintegrated.
Do you happen to know a contact address for that? I've been searching for an hour and haven't found anything!
Greetings.
Georg.
Translated on 02-10-2026, 7:58.
09-09-2010, 15:30 Subject: VW MFD Rotary Knobs: Source & Buy Now |
You can find them at "Beim freundlichen," with part number: 000 059 653 B.
They should cost around 4 euros each. MfG. Michael
Translated on 02-10-2026, 7:59.
Profile PM Garage |
09-09-2010, 18:03 Subject: VW MFD Rotary Knobs: Source & Buy Now |
Really? These are for the older MFD 1? So, the double-DIN version from 1999 onwards? That would be amazing.
Translated on 02-10-2026, 8:00.
09-09-2010, 18:07 Subject: VW MFD Rotary Knobs: Source & Buy Now |
Octavia_4x4 wrote: | | Really? Are they for the old MFD 1? So, the double-DIN unit from 1999 onwards? That would be great. |
Yes, I'm not lying to you.  MfG. Michael
Profile PM Garage |
09-09-2010, 18:53 Subject: VW MFD Rotary Knobs: Source & Buy Now |
I'm just asking if it's MFD 1 or MFD 2  .
and don't come at me with that "you know so much because the AGR is closed"  .
Translated on 02-10-2026, 8:01.
09-09-2010, 20:18 Subject: VW MFD Rotary Knobs: Source & Buy Now |
Octavia_4x4 wrote: | I'm just asking if it's MFD 1 or MFD 2  | . You wanted the part number for the buttons from the MFD 1, so I gave you the number for it:wink:. Octavia_4x4 wrote: |
:DAnd don't tell me you know so much about it just because the EGR valve is closed |  . I don't know that much either. } MfG. Michael
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
12-02-2012, 16:43 Subject: VW MFD Rotary Knobs: Source & Buy Now |
Do you happen to know a source for the electrical component of the rotary knob on the MFD 1?
Yesterday, I bought a Ford Galaxy (model year 2005, also a Sharan) with an RNS MFD system, and *after* the purchase, I noticed that the right rotary knob isn't working correctly. It jumps around erratically (for example, when entering destinations using letters). Sometimes the cursor moves in the opposite direction from which I'm turning the knob, sometimes it doesn't move at all, etc.
Online, I've only found repair offers starting from €130. I'm confident I can do the repair myself if I have the right replacement part, but currently, I'm missing that part.
Greetings.
Guste.
Translated on 02-10-2026, 8:03.
Profile PM Garage |
mullemaus Guest
12-02-2012, 16:54 Subject: VW MFD Rotary Knobs: Source & Buy Now |
Write me a private message  .
Translated on 02-10-2026, 8:04.
17-02-2012, 11:34 Subject: VW MFD Rotary Knobs: Source & Buy Now |
It seems the issue has been resolved for now. I took the part out yesterday to record its dimensions and model number (Grayhill 629985-16 or 62AY22005).
I also tried blowing it (without much hope) and bent the cable a little.
Since the installation, it seems to be working again. I only entered the code number and an address, so a real long-term test is still pending, but I haven't gotten this far before.
I'm just going to say a quick prayer now, and I'll get back to you later.
Greetings.
Guste.
Profile PM Garage |
