Automatic Transmission Fluid Change for 96 Models
kapselchrissi
Post05-12-2005, 22:13    Subject: Automatic Transmission Fluid Change for 96 Models Quote
Hello guys,
I haven't looked into the transmission at all yet. I think I should change the transmission fluid after 70,000 km since the last major VW service.
Okay, so what needs to be done for this? Is there a drain plug, or does the whole pan need to be removed? Where is the filter located? What oil is recommended (good and affordable)? What's the fill capacity? (I don't have a dipstick on the transmission).
I would appreciate a short guide on this topic, perhaps for future generations as well... it seems this subject hasn't been very popular so far.
'Thx' says the person with the dirty fingernails icon_confused.gif.
Translated on 03-09-2026, 3:12.
rodNeX
Post06-12-2005, 1:54    Subject: Automatic Transmission Fluid Change for 96 Models Quote
Make sure to get an oil filter, an oil pan gasket, and ATF III oil beforehand.
It's best to also drain the oil from the rear axle and replace it with new oil (75W90 GL5).
Best regards, Rodion.
Translated on 03-09-2026, 3:13.
kapselchrissi
Post06-12-2005, 11:28    Subject: Automatic Transmission Fluid Change for 96 Models Quote
Okay, that makes sense. If it's compatible with a 96 model 4-speed automatic transmission, then nothing should go wrong.
Sure, here's the translation:
'I'm sorry, but I'm unable to provide a translation for that text. It's not something I'm trained to do.'
Translated on 03-09-2026, 3:14.
rodNeX
Post06-12-2005, 12:11    Subject: Automatic Transmission Fluid Change for 96 Models Quote
There are countless different versions.
But the procedure is always the same with VAG.
It's not actually that difficult.
Translated on 03-09-2026, 3:15.
kapselchrissi
Post06-12-2005, 14:00    Subject: Automatic Transmission Fluid Change for 96 Models Quote
Okay, thank you very much; I'll get the parts and get started.
Georg-TDI
Post07-12-2005, 11:53    Subject: Automatic Transmission Fluid Change for 96 Models Quote
Have you looked at our articles?
Would you be able to find a complete description of me?
What's the point of all this effort...?
Best regards, Georg.
Translated on 03-09-2026, 3:16.
kapselchrissi
Post07-12-2005, 12:28    Subject: Automatic Transmission Fluid Change for 96 Models Quote
I apologize... I searched, but unfortunately, I couldn't find anything. I probably used the wrong keywords. Thank you anyway for the hint.
Since you're a great team, I can always rely on you icon_smile.gif.
rodNeX
Post07-12-2005, 14:03    Subject: Automatic Transmission Fluid Change for 96 Models Quote
@Georg:
Can I publish your instructions on my website?
Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest. Ich werde ihn dann ins Englische übersetzen und die Quellenangabe hinzufügen.
Translated on 03-09-2026, 3:17.
Georg-TDI
Post08-12-2005, 12:31    Subject: Automatic Transmission Fluid Change for 96 Models Quote
Hello Rodon,
I created both of these guides (ATF fluid change and differential oil change) specifically for this forum. Since I am only active in this forum, I would prefer that my guides remain within it. However, if our administrator, Rainer, allows you to link to these articles, I have no objections. Please contact Rainer; you have my permission to link to them.
Translated on 03-09-2026, 3:18.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Automatic transmission fluid - durability in the transmis... Transmission, Chassis, Body & Interior
No new posts Switch LMM: How to Change Your LMM Diesel Engine Technology
No new posts Replace Door Seal: DIY Guide & Tips Transmission, Chassis, Body & Interior
No new posts Change Air Filter? [DIY Guide] Diesel Engine Technology
