Pressure Sensor Connector: Find Part Number 1J0906627A
reuselkopp
Post29-12-2004, 21:43    Subject: Pressure Sensor Connector: Find Part Number 1J0906627A Quote
Hi, I'm referring to a thread (Strange questions about the VTG turbocharger pressure control!).
I'm writing about something I read. My car is a G3 Variant, AFN, manufactured in 1998. It was about identical pressure sensors in Golf 3 and 4 for the turbocharger pressure regulation. Since the sensor for a Golf 4 is much cheaper than the one from a G3, I bought the one for the 4. The only difference seems to be the connector.
Unfortunately, it seems that no one at VW is able to find the correct connector for me. So, my question is: Can anyone help me who has an AFN engine with the pressure sensor part number 1J0906627a? And could someone please provide me with the part number for the connector?
Thank you in advance.
Greetings.
Reuselkopp.
Translated on 05-10-2026, 8:20.
reuselkopp
Post31-12-2004, 13:57    Subject: Pressure Sensor Connector: Find Part Number 1J0906627A Quote
"Is there anyone who has a G4 with a 110 hp engine? This car has the pressure sensor part number 1J0906627a installed. The part number I need is printed directly on the connector for the pressure sensor. Please take a look; I don't know where else to search."
Greetings.
Reuselkopp.
Translated on 05-10-2026, 8:22.
Avatar-Jan6K
Post31-12-2004, 14:13    Subject: Pressure Sensor Connector: Find Part Number 1J0906627A Quote
The 110 hp engine in the Golf 4 is likely the ASV, not the AFN. Therefore, it's quite possible that the pressure sensor isn't functioning as it should.
Regarding the part number: Why don't you ask the "friendly" person if you can have access to the parts catalog for a few minutes? It should be very easy to find it there!
Jan.
1Z5 CFHF / AHB H4D
Translated on 05-10-2026, 8:23.
Golfchriss
Post31-12-2004, 18:57    Subject: Pressure Sensor Connector: Find Part Number 1J0906627A Quote
Hi Reuselkopp,
I was browsing the parts catalog a little bit this evening.
According to my research, the connector has 2 pins and the order number is...
1J0 973 722
Make sure to also get the appropriate pre-made cables (approximately 25cm long) for the connector.
Soldering and then covering it with heat shrink tubing will prevent it from coming loose again!
'The friendly ones' usually only come in one color, but it's better than having to deal with those tiny parts. As someone with limited fine motor skills, I've had my fair share of experiences with that.
Golfchriss
Translated on 05-10-2026, 8:24.
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BOSCH MAF Sensor Connector - Part Number Diesel Engine Technology
No new posts Find Part Number: Search & Locate Easily Transmission, Chassis, Body & Interior
No new posts Looking for resistor cable (or part number) for... H7 hea... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Looking for part number for turbo hose clamp Diesel Engine Technology
