Engine control unit locked, Golf 2 TDI AFN
ollli
Post10-09-2009, 10:33    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Hello diesel mechanics.
I had my Golf 2 with a 1.9 liter TDI AFN engine running, and it always started immediately. I then measured the large round connector with a voltmeter to determine which wire was for the parking light. Now, the vehicle won't start. I read the error codes with VCDS 908, and the error log shows "Engine control unit locked." Can you help me? I'm stuck.
Best regards.
Olli.
Post10-09-2009, 11:11    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Your connection to the immobilizer is not working, or the immobilizer may not be cooperating (combination addresses 17 or 25 for separate systems). Read out the control unit.
ollli
Post10-09-2009, 11:26    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Hello.
Thank you for the quick response. Do I need to enter the number 17 where the address is supposed to be entered, and does "Start bei vcds" indicate a starting point?
Best regards.
Olli.
Post10-09-2009, 11:33    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
ollli wrote:
Thank you for the quick response. Do I need to enter the number 17 where the address is supposed to be entered, and does "Start" refer to vcds?
Either do it like this, or you'll have to use a different dashboard. But it probably won't work because the engine/control unit is likely from a Golf III or Passat 35i. For these vehicles, you need to bypass the immobilizer (address 25) because the speedometer on these vehicles is not accessible via OBD.
Post10-09-2009, 13:55    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Combination instrument = Control panel module = Control unit address 17. The term "circuit breaker module" is not very well known, however.
Post10-09-2009, 14:15    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Rainer K. wrote:
The term 'distribution board insert' is not very well known...
Post10-09-2009, 14:35    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
No, that's not what it means. With which you simultaneously position yourself as a competitor. icon_lol.gif
I specifically replaced the term "Schalttafeleinsatz" with "Kombiinstrument" because no one actually calls that part by that name in practice. These are just those small but significant differences where, for the user, either questions arise or everything is clear. icon_cool.gif
Google says:
6,470 for switchboard installation.
143,000 for combination instrument.
The same part is therefore known under the name "Kombiinstrument" icon_idea.gif 22.3 times.
ollli
Post10-09-2009, 14:53    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Hello.
I entered the number 25 under "Selection" and then pressed "Start." The error message "No response from the control unit" appears.
Do you know how I should proceed from here?
I also clicked directly on the "Immobilizer" button, and I get the same error message.
Best regards.
Olli.
Post10-09-2009, 15:07    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Well, now you know why the engine control unit doesn't like it. icon_cool.gif
So, it's either a faulty immobilizer control unit or the wiring. I'm leaning more towards wiring.
[Edit: Please also try address 17, I'm not sure how you converted the AFN to a G2. In principle, both are possible, either a different combination instrument or a separate immobilizer control unit.] In any case, the wiring is homemade and therefore needs to be checked.
Rainer K. wrote:
You're right, point to you. I didn't know it's called something different where you are.
ollli
Post10-09-2009, 19:45    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Hello.
Thank you for your replies. I will check the wiring tomorrow. How can I tell if the immobilizer control unit is defective? Are there any identical replacement control units available for these models?
The control unit comes from a Golf 3 TDI.
Best regards.
Olli.
ollli
Post10-09-2009, 19:54    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Hello.
Is the LED on my interface constantly green, even when reading data? Is that okay?
Best regards.
Olli.
ollli
Post11-09-2009, 16:05    Subject: Engine control unit locked, Golf 2 TDI AFN Quote
Hello.
I was able to fix the problem. I connected a wire from the immobilizer to terminal 15 (positive), and it started working. The engine control unit is no longer locked.
Thank you all!
Best regards.
Olli.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine control unit locked? On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Locked? On-Board Diagnostics (OBD)
No new posts Engine Control Unit Locked: Troubleshooting Guide Diesel Engine Technology
No new posts Engine Control Unit Golf IV TDI ALH On-Board Diagnostics (OBD)
