Golf IV/Audi A4 Diagnostic Interface
tuner01
Post12-01-2005, 20:44    Subject: Golf IV/Audi A4 Diagnostic Interface Quote
First of all, good day to everyone in your forum; it's really great what I've read so far.
I would also like to delve into vehicle diagnostics using VAG-COM.
I've also built an interface based on the standard minimal wiring diagram, and it seems to be working fine. The VAG-COM software recognizes the interface and doesn't report any errors.
I'll get the OBD connector later.
Here are some questions to get us started:
What type of diagnostic interface does the fourth-generation Golf use?
I mean, are we talking about a K and L line or two K lines?
2. And what about the Audi A4 1.9 TDI from 2001 with 96 kW? And where is the OBD connector located on that model?
I'm just asking because otherwise I would be building my own "worst-case scenario" version 4.0 interface.
"3. What about the CAN bus in newer vehicles? Are there any wiring diagrams available for such an interface?"
Translated on 24-07-2026, 13:15.
Theresias
Post12-01-2005, 21:14    Subject: Audi A4 Diagnostic Interface - Golf IV Quote
1. What type of diagnostic tool does the Golf 4 have?
A K-line.
2. And what about the A4 1.9 TDI manufactured in 2001 with 96 kW? And where is the OBD connector located on that model?
Possibly 2 K-lines, depending on the configuration.
http://de.openobd.org/einbauorte.htm#audi_a4_8d
3. What about the CAN bus in newer vehicles? Are there circuit diagrams available for such an interface?
It will not happen.
Translated on 24-07-2026, 13:17.
tuner01
Post13-01-2005, 14:43    Subject: Golf IV/Audi A4 Diagnostic Interface Quote
Thank you for the information.
How can I determine if the A4 2K uses two K-lines or not? The second K-line is located where the L (live) wire would normally be, so you can't tell by looking at the connection layout.
Translated on 24-07-2026, 13:18.
Theresias
Post13-01-2005, 14:47    Subject: Golf IV/Audi A4 Diagnostic Interface Quote
A professional interface displays which diagnostic connections are available.
http://www.ross-tech.com/vag-com/tour/screens/4090/4090options_test.png
In your case, one would have to make a general conclusion based on the equipment.
Which model is your A4: the 8D or the 8E?
Translated on 24-07-2026, 13:19.
tuner01
Post13-01-2005, 22:44    Subject: Golf IV/Audi A4 Diagnostic Interface Quote
To be honest, I don't know, but the manufacturing date is June 2001.
How can I tell the difference between an 8E and an 8D?
Translated on 24-07-2026, 13:20.
Theresias
Post13-01-2005, 22:46    Subject: Golf IV/Audi A4 Diagnostic Interface Quote
Hmm... well, is it the current model (before the facelift), or is it the older model?
Otherwise, the vehicle identification number (VIN) is listed there as well.
tuner01
Post18-01-2005, 19:09    Subject: Golf IV/Audi A4 Diagnostic Interface Quote
Theresias wrote:
A professional interface displays which diagnostic lines are available.
Which model is yours, an A4 8D or already an 8E?
Can the "worst case version 4" interface be used to test whether it supports k-L or K-K?
Translated on 24-07-2026, 13:21.
Theresias
Post18-01-2005, 19:13    Subject: Golf IV/Audi A4 Diagnostic Interface Quote
Can you use the 'worst case version 4' interface to test whether it's k-L or K-K before proceeding?
More likely it's either 'K' or 'KK'.
As far as I remember, this test can only be performed with original interfaces from Ross-Tech.
Translated on 24-07-2026, 13:22.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rotating Rear Wiper Nozzle for VW Golf 4, Audi A3 8L Troubleshooting & Guides
No new posts Diagnosis Interface Diesel Engine Technology
No new posts Audi A6 Diagnosis: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Audi 80 B3 Diagnosis: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Diagnosis in the Audi V8 On-Board Diagnostics (OBD)
