Tool durability test: Does it last?
Post21-01-2005, 10:17    Subject: Tool durability test: Does it last? Quote
Since I want to work on the engine, here in the engine forum:
I have a 1/4-inch torque wrench (up to 30 Nm).
The 3/8 inch drive wrench provides up to 100 Nm of torque.
Okay, I've now purchased the adapters shown in the picture, but especially the 3/8" to 1/2" adapter doesn't seem to convey much torque.
Has anyone here had any experience with these things? Do they last a long time, or do they tend to break easily?
(Background: I only have 1/4" and 1/2" drive bits – all from Proxxon, and a few specialized sockets from Gedore.)
 zwei Proxxon Adapter, die hoffentlich halten
 File size:  61.29 KB
 Viewed:  1036 times
Translated on 20-08-2026, 22:06.
Jay_Dee
Post21-01-2005, 10:21    Subject: Tool durability test: Does it last? Quote
Do you want to know now whether Proxxon uses good quality components, or whether you can use your construction to loosen central axle nuts? icon_wink.gif
I have had very good experiences with Proxxon products, although the ratchets with the tilting lever shifting mechanism are a poorly designed flaw.
However, the Nuesse products are quite durable – much more so than comparable generic or unbranded products!
Translated on 20-08-2026, 22:08.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post21-01-2005, 12:23    Subject: Tool durability test: Does it last? Quote
I've had very good experiences with Proxon so far. I haven't been able to identify any disadvantages compared to tools from brands like Gedore or Hazet.
To be absolutely sure, I would simply try it on a different screw (one that's not critical for torque). That way, you can be certain whether the adapter holds properly. If it's from Proxon, it should work fine.
Translated on 20-08-2026, 22:09.
chris11
Karma: +3 / -1   Thank you, like it!
Post21-01-2005, 12:59    Subject: Tool durability test: Does it last? Quote
If they actually used the promised chrome steel, your 1/4-inch ratchet will likely break down sooner than this construction. And with the normally used through-handle design, the 1/2-inch part shouldn't fall apart either.
Christian.
Translated on 20-08-2026, 22:10.
Post21-01-2005, 20:07    Subject: Tool durability test: Does it last? Quote
Thank you for your help.
I just realized that I already have the icon_evil.gif 3/8 to 1/2 piece.
That's just the standard type of clamp for a 1/2 inch size – well, if it doesn't hold now, I have another one.
The 30 Nm torque for the turbo screws on the JX was more than sufficient.
Translated on 20-08-2026, 22:11.
No new posts LLM Migration Tool: Simplify Your Switch Diesel Engine Technology
No new posts Valve Stem Seal Tools: Repair & Replacement Diesel Engine Technology
No new posts Tool for adjusting distributor injection pumps VW Diesel Engine Technology
No new posts Vehicle Front Alignment Tool for Service Diesel Engine Technology
