LLM Migration Tool: Simplify Your Switch
passatfrust
Post25-01-2005, 19:04    Subject: LLM Migration Tool: Simplify Your Switch Quote
'After my Passat TDI (AVF, 130 hp) has become noticeably sluggish and lost power, and the service technicians at two workshops could only say 'all measured values are within the normal range... everything is fine!', I now want to replace the mass airflow sensor (MAF sensor) with the Pierburg MAF sensor that is now approved, and I'm hoping this will fix the problem!'
Unfortunately, you can't remove the old mass airflow sensor with a standard T20 Torx screw; you need a special VW part that looks like a 5-pointed star with a hole in the middle... I'm not even sure what to call it.
It's not available locally from any tool specialty retailers.
Where can I get this bit or socket? Ideally, at the lowest possible price? And what size is it?
Thank you all in advance for your help!
Translated on 18-10-2026, 6:28.
Post25-01-2005, 19:50    Subject: LLM Migration Tool: Simplify Your Switch Translating...
[Translating...]
http://www.hazet.de/deutsch/katalog/suche_3.asp?F=2225&H=60&U=110
passatfrust
Post26-01-2005, 9:52    Subject: LLM Migration Tool: Simplify Your Switch Quote
Thank you, Ulf, for the link!
Can anyone tell me the size? Is it 20, 25, or 27...?
passatfrust
Translated on 18-10-2026, 6:30.
Post26-01-2005, 10:28    Subject: LLM Migration Tool: Simplify Your Switch Quote
Okay, Passat.
Why don't you first talk to your VW colleagues and ask them for the specific values?
"Even within the 'green zone' for air-fuel ratio, my TDI doesn't run well; it performs much better with 850 mg per stroke."
Then, post the values here, and we'll tell you if they're okay.
Wildes TeileTauschen is like adding spoilers to increase performance icon_wink.gif.
Alois
Post26-01-2005, 12:37    Subject: LLM Migration Tool: Your Guide Quote
Unfortunately, you can't remove the old mass airflow sensor with a standard T20 Torx screw. Instead, you need a special VW part that looks like a 5-pointed star with a hole in the middle... I'm not even sure what to call it.
If you want the cheapest option: simply grip the edge with pliers. If it's loose, use a small screwdriver to insert it between the shaft and the hexagonal part and twist it all the way out. Assembly is in the reverse order.
Translated on 18-10-2026, 6:32.
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Tool durability test: Does it last? Diesel Engine Technology
No new posts Valve Stem Seal Tools: Repair & Replacement Diesel Engine Technology
No new posts Tool for adjusting distributor injection pumps VW Diesel Engine Technology
No new posts Vehicle Front Alignment Tool for Service Diesel Engine Technology
