Ibiza: Where is the NTC water connection?
Pitrie
Post10-02-2005, 11:58    Subject: Ibiza: Where is the NTC water connection? Quote
I have a problem.
Seat Ibiza / 90HP / 1.9 TDI / Year of Manufacture: 2000
And the problem is that my temperature gauge isn't working!
However, occasionally it jumps up to 90 degrees Celsius for a few kilometers.
Now, I wanted to check the NTC, but do you think I'll find it? icon_confused.gif
Can someone tell me where he/she is?
'Is that the thermostat where there are three small indicator lights?'
So, it would be great if someone could help me!
thx[/b]
Translated on 28-07-2026, 0:04.
Post10-02-2005, 12:07    Subject: Ibiza: Where is the NTC water connection? Quote
Oops!
Don't twist things around!
Okay:
- The thermostat is located directly on/inside the water pump (which is mounted on the engine below the alternator/power steering pump).
- The candle part is separate and only provides warmth.
- The dual temperature sensor (one for the display, one for the engine computer) is located on the upper coolant hose at the engine, which leads to the radiator. It should have a 4-pin connector attached.
Is it clear now?
Translated on 28-07-2026, 0:05.
Pitrie
Post10-02-2005, 12:30    Subject: Ibiza: Where is the NTC water connection? Quote
aha...
Okay, I think I've found the NTC!
That will be the one that faces backwards and is located near the glow plug module, right?
I can't get the connector off at all, but I'll drive later and then mess around with the connector when it's warm. That way, I'll see if it's just a loose connection!
Can I somehow test the glow plugs from the heating module using the control system?
My friend is taking a very long time to get hard, and maybe there's something wrong with the stimulation.
They definitely have a resistance of 1 ohm (all three), but I wasn't able to measure the voltage.
Translated on 28-07-2026, 0:07.
Post10-02-2005, 12:46    Subject: Ibiza: Where is the NTC water connection? Quote
You have that one there.
/content.php?c=8
and that:
Not really thoroughly worked out, right?
Translated on 28-07-2026, 0:09.
Mephisto
Karma: +14 / -1   Thank you, like it!
Post10-02-2005, 16:56    Subject: Ibiza: Where is the NTC water connection? Quote
Hi Pitrie,
For basic questions like "Where is the thermostat located?", I can recommend books such as "How It's Done" or "Help Yourself." If you start tinkering with anything that looks like a thermostat, you're more likely to break things than fix them.
(And just between us: You're probably not going to make any friends with the moderators by asking questions like that.)
"Micha"
Translated on 28-07-2026, 0:10.
Avatar-Jan6K
Post10-02-2005, 18:02    Subject: Ibiza: Where is the NTC water connection? Quote
"This is how it's done" or "I'll do it myself now."
...which are not available for the Ibiza 6K GP01.
However, the TDIs are essentially identical to those found in the Golf 4 (same engine code... for the ALH or ASV TDI engines), so consulting relevant Golf 4 manuals should be helpful.
Jan.
1Z5 CFHF / AHB H4D
Translated on 28-07-2026, 0:11.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts oil water heat exchanger Diesel Engine Technology
No new posts Water-Diesel Mix: Opinions and Reviews Diesel Engine Technology
No new posts Seat Ibiza 110PS TDI: Upgrade to G3 Diesel Engine Technology
No new posts Seat Ibiza 6L engine swap, 118 kW Diesel Engine Technology
