Fitting a rear subframe from an Audi A6 into a Golf?
sascha
Post24-04-2002, 22:46    Subject: Fitting a rear subframe from an Audi A6 into a Golf? Quote
Can anyone tell me if I can install a tuning box (from Küberl Tuning, has an adjustment screw and is connected with 3 cables: 1x ground, 1x pump signal, and 1x input signal/power supply; it was previously installed in an Audi C4 5-cylinder TDI) in a Golf 3 TDI from 1995 with 66 kW? If so, which cables should I connect it to?
Alex.
Post25-04-2002, 16:17    Subject: Re: Connection diagram?? Quote
sascha wrote:
Can someone tell me if I can install a tuning box (from Küberl Tuning, has an adjustment screw and is connected with 3 cables: 1x ground, 1x pump signal, and 1x input signal/power supply, and was installed in an Audi C4 5-cylinder TDI) into a Golf 3 TDI, year 1995, 66 kW? If so, which cables should I connect it to?
Hmm, the description of the connection diagram already seems strange to me: Normally, speakers are always connected to the pump cables in two ways: either cable 1 is disconnected, or cables 2 and 3 are "bridged" through the box (don't take that literally as a short circuit!).
Since, in my opinion, both vehicles essentially have the same pump (VP 37), the control unit should be transferable. That, of course, doesn't say anything about whether something is legal or illegal (expert opinion??).
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rotating Rear Wiper Nozzle for VW Golf 4, Audi A3 8L Troubleshooting & Guides
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Does this catalytic converter fit a Golf with a 1Z engine? Diesel Engine Technology
No new posts Peeling Paint on Golf 5: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Problem with an ATM Diesel Engine Technology
No new posts AJM -- Soot on a tandem pump hose Diesel Engine Technology
