Change Clutch Yourself? DIY Guide & Tips.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post02-02-2005, 12:09    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
After finding nothing in my search, I'm reaching out to the experts directly.
"The clutch in my AGR 3/97 is starting to fail after 216,000 km, and since I've decommissioned my A3 after an accident, I'm considering replacing the clutch myself to save money. The front components are already removed, which makes it easier to access the transmission. A reinforced clutch from ALL4TDI would cost around 300 euros."
Is this something that I, as a hobbyist, can realistically do? I certainly have enough time to undertake the replacement.
I would like to extend the fifth gear ratio at this opportunity.
What do you mean?
Translated on 30-08-2026, 14:02.
Post02-02-2005, 12:19    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
If you have the necessary time, space, and tools, then there's nothing stopping you. In principle, you don't need to remove the front of the car. The easiest way is to catch the engine from above, secure it to prevent it from tilting, and have the car on a lift. If only ramps are available, it's quite a feat of strength to separate the transmission from the engine. How are you planning to do it? With a lift? Well, if the car isn't needed right now, I would do it myself.
Translated on 30-08-2026, 14:04.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post02-02-2005, 12:26    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
If you also have a digital camera available, I would suggest taking some pictures before disassembling anything. That way, you can always refer back to them to see where each part goes. I would also label the cables and connectors with Tesa tape and put the screws in separate containers; this will greatly simplify the reassembly process.
Ultimately, you can only answer that question yourself.
Translated on 30-08-2026, 14:05.
Holger247
Post02-02-2005, 12:55    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
I would also recommend using a lift. And definitely have a strong helper on hand when removing or installing the transmission. I once changed the clutch on a Polo II, and the transmission was already quite heavy, especially when you have to move it back and forth to find the right position.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 30-08-2026, 14:06.
dj1
Post02-02-2005, 13:11    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
I would like to know how much it would cost to have a clutch replaced on a VW.
Does anyone happen to know the price?
DJ.
Translated on 30-08-2026, 14:07.
Tagessuppe
Post02-02-2005, 13:15    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
Okay! If you think it's possible, then I guess I'll give it a try.
I thought I could lift the car up completely on one side using the jack, so that you could easily get underneath it.
Was muss ich denn alles Abmontieren um das Getriebe abzubekommen. Driveshaft?
So, I need to support the engine, is that correct?
Are there any other areas where things could become critical, or where I might need special tools, such as a centering mandrel for aligning the clutch?
Thank you very much for all the answers.
Translated on 30-08-2026, 14:08.
Post02-02-2005, 14:19    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
Forget about it.
1. Extremely dangerous; if the tractor slips, you could be crushed (not just unhappy, but DEAD).
And you really have to put in a good amount of effort there.
2. And that brings me to the next point: fundamentally, you lack power.
I just managed to get about 20 Nm of torque on the oil pan - no problem doing it underneath the car.
3. The working height may not be sufficient if, for example, you need to loosen the drive shafts using large wrenches.
It might be possible to proceed without a stage, but if not, we'll use a platform. In any case, we'll definitely place the cart on blocks.
Translated on 30-08-2026, 14:09.
wollif
Post02-02-2005, 16:09    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
'It doesn't quite fit the topic, but I'll ask anyway:'
I suspect my clutch is slipping. It's noticeable in 5th gear when accelerating from low RPM. It feels like the clutch is 'slipping in waves,' only engaging every half rotation. When you release the gas pedal, everything goes back to normal.
Here's what I specifically want to know: How long can the car still be driven (days, weeks, months)? Does anyone have experience with this? I mostly drive on the highway and therefore shift gears very little.
Greetings.
wollif
Volkswagen Golf III 1Z, manufactured in 1994, with 280,000 km mileage.
Translated on 30-08-2026, 14:11.
Tagessuppe
Post02-02-2005, 16:26    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
After a lot of starting and stopping, the clutch can sometimes start to slip, especially if it was already worn. My clutch started slipping about 2 years ago, after a period of city driving. After 300 kilometers on the highway, the problem disappeared.
But I think it will probably be due soon, considering the mileage on your car.
Translated on 30-08-2026, 14:13.
mahk
Avatar-mahk
Post02-02-2005, 16:56    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
Okay, so I've only done this twice, on a Golf Mk2, but basically, it's not reinventing the wheel. Especially since you also have a transversely mounted engine. Remove the left driveshaft, loosen the right one at the transmission and let it hang, then remove the engine, support it, and move it to the right. Loosen the transmission and remove it from below. I had a lift, but no engine hoist. But with this car, the paint wasn't really a big issue, so you could improvise with some household tools.
http://wittke.bluehash.de/misc/motorraum.jpg
Only the starter motor is connected by the wire, while the engine is connected by the thick cable.
Regarding the centering process, I used the caliper to adjust it until the carrier disc was centered. It worked. The removal of the pressure plate was a bit tricky, as it wasn't held in place with hex bolts. However, a slightly modified ring wrench also worked.
gamz on the edge: The clutch in my Audi, with almost 300,000 km on the clock, still hadn't given me any problems. But it was also a car primarily used for long-distance driving...
Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ([email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
Translated on 30-08-2026, 14:15.
Tagessuppe
Post02-02-2005, 17:06    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
Thank you, dear Mahk.
You've helped me a lot.
Now, I'm going to dare to icon_biggrin.gif.
Translated on 30-08-2026, 14:18.
wutz
2006 Seat Leon
Post03-02-2005, 9:18    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
With the Golf II, it wasn't a problem to change the clutch, especially with the gasoline engine. There was plenty of space to work, but it was a bit tighter with the diesel engine.
The cables and connectors were also quite manageable in the II model.
@SoupOfTheDay
As Dieselmartin already mentioned, the car should be properly supported with jack stands and not just resting on a jack.
Make sure to properly center the clutch disc, and when tightening the pressure plate, work evenly to avoid having to do the job all over again. I used the handle of an old ratchet as a centering tool on my II. I sanded the end down a bit (so it fit into the flywheel) and the handle went straight through the clutch, and it worked quite well.
Translated on 30-08-2026, 14:19.
Tagessuppe
Post03-02-2005, 10:52    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
wutz wrote:
@SoupOfTheDay
Alright! When I'm working under a raised car, I only do it with at least two jack stands and a support stand shaped like a tree trunk.
Translated on 30-08-2026, 14:20.
thom
Post04-02-2005, 16:24    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
Without a lift, I would advise against it, especially if you've never done it before.
Forget about doing that with a few jacks and some logs (it's very dangerous).
If you want to do it yourself, please find a rental workshop; that's definitely safer.
Translated on 30-08-2026, 14:21.
Back to top Profile PM Email
Tagessuppe
Post04-02-2005, 16:32    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
thom wrote:
If you want to do it yourself, please find a rental workshop, that is definitely safer.
I would love to, but my car isn't working right at the moment.
That's precisely why I wanted to use this forced break as an opportunity to make a change.
Best regards.
christians
Post05-02-2005, 2:23    Subject: Change Clutch Yourself? DIY Guide & Tips. Quote
With a transverse engine, everything is easily accessible even without a lift. While a log might seem secure, "threading" the gearbox onto the engine certainly won't be easier if the car is jacked up unevenly and at an angle. On the other hand, you don't need a huge amount of space underneath. However, it's not ideal to do it alone, especially if, as I suspect (otherwise the question wouldn't be here), you're not very experienced.
Gruß Christian
Translated on 30-08-2026, 14:22.
No new posts P0011 - Camshaft Timing Delayed: Not Reached Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Replace ZR on AKN Yourself? Diesel Engine Technology
No new posts Replace Solenoid Valve: DIY Guide & Tips Diesel Engine Technology
No new posts Replacing front wheel bearings yourself Transmission, Chassis, Body & Interior
No new posts LMM - Target vs. Actual On-Board Diagnostics (OBD)
