Auxiliary heater and dirt in the engine compartment
TOLAR
Post30-01-2005, 16:30    Subject: Auxiliary heater and dirt in the engine compartment Quote
After a lot of driving in the past few days on the salt-covered highway (with the resulting spray), I noticed that the engine compartment on the left side of my Golf IV TDI (AXR, 7-2003) was heavily soiled. Dirt and salt deposits are visible from the engine cover to the air filter and the battery. Apparently, the dirt/saltwater originated from spray emitted by vehicles traveling ahead.
'I didn't notice this effect BEFORE the installation of the auxiliary heater in January 2005 (Webasto TTE). The engine compartment was always clean. Therefore, it's likely that something went wrong during the installation (e.g., the trim wasn't properly mounted).'
Before I file a complaint, I'd like to ask everyone who also has a Webasto TTE installed: Can you also observe such contamination in your units?
Thank you for your help!
Peter.
Bee
Post30-01-2005, 21:24    Subject: Auxiliary heater and dirt in the engine compartment Quote
The trim panel between the wheel arch and the engine compartment is cut during installation to allow the water hoses to pass through. If this cut is too large, it's obvious that dirt can easily find its way into the engine compartment. A properly sized trim panel, cut to fit, should easily solve this problem. But be careful that the coolant hoses don't rub against the fairing.
'Micha'
Holger247
Post31-01-2005, 14:01    Subject: Auxiliary heater and dirt in the engine compartment Quote
Actually, not the best location for the auxiliary heater, is it? Being in the fender well.
Pollution is just one problem. The expensive auxiliary heater, being located in the fender, is also much more likely to be damaged (e.g., by minor parking accidents). And I'm sure the water pipes aren't the shortest either.
Has anyone relocated the auxiliary heater in a Volkswagen Golf IV?
Okay, the engine compartment isn't exactly spacious... I was thinking about the space in front of the fender liner on the passenger side. Has anyone perhaps done something like this before?
GIV - 98 - ALH
Touran 5T 2.0 TDI
No new posts A3 Windshield Stain: Documentary (8P1) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L Doku: Engine Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Oil everywhere in the engine compartment... Diesel Engine Technology
No new posts Terminal 15, engine compartment / central electronics box Electrical Systems, Vehicle Electronics, Multimedia
No new posts Switched plus wire in the engine compartment ?? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Polo 6N1 AEE 1.6L engine bay oil leak/contamination Gasoline Engine Technology
