Brief conclusion with Pierburg MAF sensor
Corradoman
Post06-05-2005, 16:17    Subject: Brief conclusion with Pierburg MAF sensor Quote
I finally installed the Pierburg mass airflow sensor (part number 7.22684.08.0) in my ALH engine, and I'd like to share a brief summary of my experience:
It's indescribable...
It readily revs from 900 to 4000 RPM in gas mode, there's no more hesitation, and it also accelerates smoothly and "without bogging down" in fourth gear from 2000 RPM.
It's really not comparable to the Bosch part that Volkswagen installed.
Those 60 euros that he spent on accessories have definitely already paid for themselves after just the first ride.
Thank you for your attention.
94er VW Corrado 16V für die sonnigen Tage im Jahr. Mein Alltags-Fahrzeug:
Golf IV Variant TDI,Bj 2000 mit ALH-Motor und bescheidener Leistung von 90PS -> verkauft
Touran "Freestyle" Modell 2010, BSE-Motor und niedlichen 102PS -> verkauft
Jetzt 2013er Nissan Qashqai 110 Diesel-Pferde
Translated on 17-07-2026, 1:27.
SeatLeon
Post07-05-2005, 3:31    Subject: Brief conclusion with Pierburg MAF sensor Quote
Was your Bosch mass airflow sensor (MAF) defective, or are you comparing two perfectly functional MAF sensors here?
Translated on 17-07-2026, 1:29.
Corradoman
Post07-05-2005, 8:05    Subject: Brief conclusion with Pierburg MAF sensor Quote
So, it wasn't really broken yet.
It was clear that he didn't have much time left to live. Between years 2800 and 3100, there wasn't much happening, but things started to go reasonably well from around 3100 onwards. However, everything felt tough and slow.
I'm going to say this now, but I believe that even when it was brand new, it didn't drive as well as it does now with the Pierburg part.
R.M.
Karma: +14 / -0   Thank you, like it!
Post07-05-2005, 12:11    Subject: Brief conclusion with Pierburg MAF sensor Quote
So, I've already had a direct comparison between a Bosch mass airflow sensor that was 2 years old and a brand new Pierburg one (still warm from the parts store).
Conclusion: There was no noticeable difference. (Subjective driving experience, without any measured values).
So, I guess either I got a bad Pierburg unit, or yours was already completely broken.
Translated on 17-07-2026, 1:30.
Hati
Post07-05-2005, 12:16    Subject: Brief conclusion with Pierburg MAF sensor Quote
So, if both mass airflow sensors (MAF sensors) are functioning correctly (verify this by checking logged values), then there should be no difference or at most a very slight difference noticeable.
Translated on 17-07-2026, 1:31.
Corradoman
Post07-05-2005, 14:22    Subject: Brief conclusion with Pierburg MAF sensor Quote
Then the Bosch component was probably already completely worn out.
I'll reinstall it and run some tests to get a proper comparison.
Translated on 17-07-2026, 1:32.
lappen
Post07-05-2005, 20:19    Subject: Brief conclusion with Pierburg MAF sensor Quote
Hey guys, how about you try posting in the relevant existing threads and actually read them?
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts New small Avatar Upload
No new posts RNS Radio Issues: Troubleshooting & Solutions Transmission, Chassis, Body & Interior
No new posts Audi B5, 1999 - Retrofitting from small navigation system... Transmission, Chassis, Body & Interior
No new posts Pierburg 1.9 Tdi Tandem Pump Diesel Engine Technology
