10 Cent Coin: Experience & Value Insights
Post11-04-2004, 9:12    Subject: 10 Cent Coin: Experience & Value Insights Quote
Hi.
I built a 10-cent box containing 680 resistors, plus the option to add either a 1,000-ohm or a 5,000-ohm potentiometer.
Okay, so still without the diodes. I haven't experienced any runaway issues, but I've been running the box at its maximum output (effectively shorting the potentiometer) and using only the 680-ohm resistor.
I haven't seen any "Russ" (likely a typo or nickname), and I definitely felt more agility. It's true that the engine is now more responsive in the lower gears, but it also pulls better in the higher gears.
DZR (take-off distance) shortened from 9.3 to 7.9 meters on a very slightly uphill runway (G3 Var with some luggage and 2 people -> approximately 1450 kg maximum take-off weight).
What values are the other 10 users in this forum getting?
Translated on 26-09-2026, 10:59.
x world one
Post11-04-2004, 9:48    Subject: 10 Cent Coin: Experience & Value Insights Quote
With 185/60 R14 tires, I needed 8.3 seconds in the DZR mode. With the 10C setting, I was able to reduce that time to 6.5 seconds.
I always drove alone, and whether the tank was half full or full never seemed to make a difference, at least not if you were only measuring it with a stopwatch.
Spritmonitor
Translated on 26-09-2026, 11:00.
Post11-04-2004, 13:35    Subject: 10 Cent Coin: Experience & Value Insights Quote
Hm, x world.
Okay, so you probably don't have a variant (different transmission, heavier version).
But what resistance values (with or without diodes) did you use?
Translated on 26-09-2026, 11:01.
x world one
Post11-04-2004, 14:00    Subject: 10 Cent Coin: Experience & Value Insights Quote
It's a 2-door model with an ASD transmission. The potentiometer's resistance measures 369 ohms; it's a 2k ohm potentiometer. I just checked it, and with that value, it performed well. That's why I'm disappointed with my current control box, as it doesn't even come close to that performance. I'll take it to a specialist for adjustment.
Okay, the weight of the 2-door model is stated as 1120 kg. Adding my weight (80 kg) brings the total to 1200 kg. I don't know how much fuel weight will be added to that, as the measurements were taken with both a half-full and a full tank, and the differences were relatively small.
Spritmonitor
Translated on 26-09-2026, 11:02.
hollari
Post09-02-2005, 15:22    Subject: Tuning: Speedometer & RPM Gauge Video Quote
see: http://free.pages.at/hollari/
Translated on 26-09-2026, 11:03.
Post09-02-2005, 17:05    Subject: 10 Cent Coin: Experience & Value Insights Quote
Tja, das Video verlangt nach irgendnem wilden Codec. I don't see anything.
Besides, I don't think it conveys much more than just the raw numbers.
hollari
Post10-02-2005, 9:46    Subject: Codec: Definition, Types & Examples Quote
I installed the DivX 4.12 codec.
That should do the trick.
If not, then I'll find a way to convert the video somehow.
Translated on 26-09-2026, 11:04.
Post10-02-2005, 9:50    Subject: 10 Cent Coin: Experience & Value Insights Quote
Nope, still nothing.
But I should already have the codec.
A direct comparison (split-screen) between versions with and without the box would be very interesting.
m
wolfi_b
Post10-02-2005, 10:00    Subject: 10 Cent Coin: Experience & Value Insights Quote
Well, I see it, but I'm wondering what you're trying to say with it.
Instead of posting those numbers, why don't you share the DZR figures? That way, we can actually compare things.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 26-09-2026, 11:05.
Jan03
2010 Volkswagen Polo
Post10-02-2005, 20:30    Subject: 10 Cent Coin: Experience & Value Insights Quote
Hi.
I also have a potentiometer on the pump connector. It doesn't have a diode, but that doesn't seem to be a problem with the early 1Z models. My engine control unit (ECU) definitely doesn't perform a start check, because I can adjust anything I want, and it always starts (even if it doesn't run properly afterwards).
I'm at 530 ohms. It's just enough that the idle speed (with the 1Z pump) returns to a reasonable 800 RPM. The dwell time is (as far as I remember) 7.4 seconds. However, as soon as the engine exceeds approximately 2800 RPM, it starts to misfire significantly. This is because my boost pressure has quite large overshoots at lower RPMs (1.1 bar) and only drops back to 0.8 bar at 2800 RPM. I've been meaning to address this for a while, but I haven't had the chance yet.
By the way, it seems that with an AFN pump (which was cheaper icon_rolleyes.gif) in a 1Z engine, you can apparently push the 10-cent tuning a little further without the idle control becoming unstable. However, it might just be a coincidence, and mine is already producing enough smoke anyway. icon_sad.gif
Generally, I can say that the car, with the 10-cent modification, is quite responsive in all gears, and I don't think I can live without it anymore. Before, it couldn't even pull a small fish.
/Jan
G3, 1994, 1 owner, 191,000 km, (AFN-ESP and injectors)
Translated on 26-09-2026, 11:07.
Post11-02-2005, 1:04    Subject: 10 Cent Coin: Experience & Value Insights Quote
Hm, AFN turbos and "only" 7.4 seconds??
Ich mach mit 185 Tkm alter Orginal 1Z Ausstattung ja schon 7,6 - und das im schweren Variant (ok, der hat auch nen deutlich kuerzeren 3. Okay!
But I could also use some new icon_smile.gif nozzles. But let's go through everything in order }.
m
Translated on 26-09-2026, 11:09.
No new posts 10Cent Tuning Technical Articles
No new posts Top Speed 1Z: Real-World Results & Data Diesel Engine Technology
No new posts Hoping for practical experience Diesel Engine Technology
No new posts DZR Experience (mine is too weak) Diesel Engine Technology
No new posts Expected lifespan of T6 shock absorbers Transmission, Chassis, Body & Interior
