Hi Klaus,
The part is called "KSB", which stands for "KaltStartBEschleuniger" (Cold Start Accelerator).
I know him well, because we have already adjusted the ESP twice from the AAB, even when the KSB was still engaged
According to BOSCH, the KSB (likely a component related to heating or cooling) provides approximately 2.5 degrees of advance heating. However, this only applies up to a certain speed, roughly as follows:
