Where does the "spin" originate?
corry16vturbo
Post13-02-2005, 18:26    Subject: Where does the "spin" originate? Quote
A diesel engine requires a "swirl" for proper combustion.
Where and how exactly is the spin generated?
Is it not possible to widen the channels in a simple way?
Does the spin get lost?
How about larger valves?
best regards
Torsten.
Hubraum ist durch nichts zu ersetzen außer durch mehr Ladedruck ...
Translated on 10-09-2026, 3:37.
syncro peter
Post13-02-2005, 21:33    Subject: Where does the "spin" originate? Quote
hello
'It's not just the diesel engine that needs swirl, but swirl is often a combination of swirl and tumble, which is then called 'tipped'. The way these movements are created depends on the type of injection: direct, pre-chamber, or swirl chamber. Furthermore, it depends on the valves, the position of the valves, and the intake manifold. If you want to make any changes, it's best to do so on a flow bench.'
I hope I've helped you.
peter
Translated on 10-09-2026, 3:38.
corry16vturbo
Post13-02-2005, 23:27    Subject: Where does the "spin" originate? Quote
Hello Peter,
Thank you very much for your reply.
First of all, I want to mention that my car is a TDI, which means it's a direct injection diesel engine. Is the airflow behavior comparable to that of a gasoline engine?
Following the motto: What is good for a gasoline engine, cannot be bad for a diesel engine.
Does the "classic tuning" typically applied to gasoline engines also work with diesel engines?
What if I polish the valve guides and the valve seats?
What needs to be considered?
Unfortunately, as a private individual, I do not have access to a wind tunnel.
Sincerely,
Torsten.
Translated on 10-09-2026, 3:40.
christians
Post14-02-2005, 1:25    Subject: Where does the "spin" originate? Quote
Without further modifications, polishing alone won't achieve much because while it might allow for slightly more air, it will also let in the same amount of diesel into the cylinders. For a TDI engine, the first step is usually a chip tuning or power box, followed by larger injectors and a turbocharger.
For a naturally aspirated gasoline engine, things are naturally different.
Gruß Christian
Translated on 10-09-2026, 3:41.
Post14-02-2005, 9:54    Subject: Where does the "spin" originate? Quote
@ Corry (as an explanation regarding Christians)
Here, the saying "What's good for a gasoline engine..." does NOT apply.
The gasoline engine sucks in the air-fuel mixture. So, if you can increase the volume of air flowing through by widening and polishing the channels, more of the mixture will enter the cylinder, resulting in a bigger "bang" and thus more power.
With a diesel engine, you are only introducing more __air__ into the cylinder - of which there is already "too much," because diesel engines always operate with an __excess__ of air.
A 1Z engine (90 HP TDI in a Golf3) can have up to 20% more air in the cylinder than it needs for the standard fuel injection amount (required for clean combustion).
That means you can burn almost 20% more diesel without producing soot, all without making any mechanical changes. That's exactly what a "10 Ct. Tuning" or a simple power box does (by simply injecting more diesel). Only after you've already used up this "gift" of excess air do you need to add more air. But even then, hardly anyone will polish the intake channels; that's what the turbo is for. So, by using a chip (or even a "10 Ct. Tuning"), increase the boost pressure and inject even more diesel.
Translated on 10-09-2026, 3:43.
corry16vturbo
Post14-02-2005, 12:42    Subject: Where does the "spin" originate? Quote
Thank you for the detailed explanation.
I think I understand.
Currently, I only offer performance enhancements for gasoline engines.
t.
Translated on 10-09-2026, 3:45.
Post14-02-2005, 12:50    Subject: Where does the "spin" originate? Quote
Here's another beautiful picture showing what polished channels can achieve in a TDI engine that has been running for a long time (after 180,000 km):
http://www.luxus-wg.de/~martin/auto_bilder/AGR_Saugstutzen/Kopf_3-2.jpg
Well, there's nothing polished here - but if there were, no one would notice it anyway.
The AGR (Abgasrückführung) and oil mist in the intake manifold create a "bake-bake-cake" situation.
http://www.luxus-wg.de/~martin/auto_bilder/AGR_Saugstutzen_sauber/
http://www.luxus-wg.de/~martin/auto_bilder/Kruemmer/
Translated on 10-09-2026, 3:46.
corry16vturbo
Post14-02-2005, 13:04    Subject: Where does the "spin" originate? Quote
That looks really dirty and grimy.
After the cleaning, it was very clean, and could you notice a difference in how it ran?
Where does the dirt come from?
KW-Ventilation + EGR?
t.
Post14-02-2005, 14:28    Subject: Where does the "spin" originate? Quote
The dirt is coming from the cooling system vent, but also likely from a slightly leaky turbo, and then there's the soot from the EGR valve.
I didn't immediately notice any differences in the driving experience, probably because I changed several things at once and hadn't driven for a while.
m;:
Translated on 10-09-2026, 3:47.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts Austausch des RNS315 gegen neues "Discover Media" Electrical Systems, Vehicle Electronics, Multimedia
