Are braking noises normal? - Are the brake discs warped?
ObenbeiMutti
Post14-02-2005, 17:06    Subject: Are braking noises normal? - Are the brake discs warped? Quote
A popular topic in this section is brakes.
The combinations of rotors and pads from different manufacturers are often a topic of discussion.
I had the brakes and pads replaced about 80,000 kilometers ago.
I inadvertently used relatively inexpensive standard products from a free-market workshop chain based in Upper Palatinate, which is active throughout Germany.
I have to say, I always took pride in my car's brakes, which were the best factory-installed brakes available (288mm discs - the last VR6 brake system).
She was and still is very assertive, especially when it comes to city driving! But is it stable?
Indication:
'When I have to brake from 180 km/h to 100 km/h on the highway (due to trucks, elderly drivers swerving, etc.), and I'm not even applying a full brake, I'm already braking from 180 to 160 km/h. Below 160 km/h, a significantly greater amount of pedal force is needed to achieve the same braking effect. At the same time, a noise becomes louder, which I can't quite describe. It sounds like: 'rurururururururu'.' The steering wheel doesn't vibrate, and the vehicle maintains its lane.
Question:
Does this indicate slightly warped rotors? The old (original) rotors and pads made no noise. Shouldn't such large iron discs be able to handle a good amount of weight (G3)? Or am I just being hysterical again, and everyone knows about the effect of increasing pedal pressure?
Thank you, everyone.
Tobias.
Post14-02-2005, 18:02    Subject: Are braking noises normal? - Are the brake discs warped? Quote
I've only driven about 100,000 km with this Girling system in my G III (without replacing any parts), but it was by far the best braking system I've ever experienced. I still miss it today... Sounds were completely foreign to this brake, whether it was panic braking from maximum speed icon_eek.gif or a reckless descent down the Großglockner mountain road with the digital use of gas and brake icon_twisted.gif.
From my other cars, I'm familiar with the brake noise that comes from worn discs and/or pads. Whenever new parts were needed, these noises would often appear, sometimes accompanied by a grinding sound. I would attribute this effect to the potentially worn-out replacement parts. I would definitely go back to using original parts for the next replacement.
No new posts Warped Rotors After Brake Pad Change? Transmission, Chassis, Body & Interior
No new posts Brake Disc Bore: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Brake Discs Overheating: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Brake Pads Replacement Rear Axle Transmission, Chassis, Body & Interior
