Gear Ratio 6-Speed AAT/AEL
Markus H.
Post01-02-2005, 21:46    Subject: Gear Ratio 6-Speed AAT/AEL Quote
Could the Audi C4 drivers with the 6-speed transmission in this forum please post some speeds along with the corresponding RPMs?
I am only interested in the 6th gear (ARX transmission).
I would find speeds like 80, 100, 130, and 180 km/h interesting.
Is the 5th gear significantly shorter than the 5th gear in a 6-speed transmission (CEP)?
For example, at 150 km/h, I have approximately 3,000 RPM.
THANK YOU!
Translated on 09-09-2026, 0:17.
christians
Post01-02-2005, 22:49    Subject: Gear Ratio 6-Speed AAT/AEL Quote
http://www.dieselschrauber.de/GKB.html
By the way, my car's engine also runs at 3000 RPM at 150 km/h (according to the speedometer).
Translated on 09-09-2026, 0:18.
ivanovic
Post05-02-2005, 17:37    Subject: Gear Ratio 6-Speed AAT/AEL Quote
Do you have a viscous coupling or a V-belt in the transmission?
Mampf
Karma: +8 / -1   Thank you, like it!
Post05-02-2005, 20:40    Subject: Gear Ratio 6-Speed AAT/AEL: Specs & Details Quote
Audi 100 Avant EZ 5/94 (einer der letzten, Verkabelung für ZV-Pumpe schon vom A6 icon_lol.gif ), Werte laut Tacho im 6. Gang:
1800 RPM at 100 km/h.
2500 RPM at 140 km/h.
Munch.
Translated on 09-09-2026, 0:19.
Markus H.
Post12-02-2005, 15:05    Subject: Gear Ratio 6-Speed AAT/AEL Quote
'Thanks, that's how I calculated it now too.'
That already brings about a significant reduction in noise and energy consumption.
Right now, my 6-speed transmission is being installed - I'm already excited. icon_smile.gif
Financially, it's probably not something that can be easily reversed, but I'm mainly interested in the aspect of comfort.
Translated on 09-09-2026, 0:20.
bastianna
Post25-02-2005, 8:40    Subject: Gear Ratio 6-Speed AAT/AEL Quote
hello Markus,
Tell me, what are your first impressions of the 6-speed transmission?
Hi Bastianna,
Das Leben ist schön, wenn man es lebt.
Translated on 09-09-2026, 0:21.
Markus H.
Post25-02-2005, 16:44    Subject: Gear Ratio 6-Speed AAT/AEL Quote
Well, a certain degree of car enthusiasm is a prerequisite to consider such a project worthwhile. icon_wink.gif
As I mentioned before, the cost of the 6-speed transmission is not insignificant, and the complex installation also requires several hours of work, even in a competent independent workshop.
On the other hand, I was fortunate enough to find a company that was willing to trade my old 5-speed gearbox for a 6-speed one at a reasonable price (!).
Ask your Audi dealer about it – it's guaranteed to make him laugh.
That's all there is to it.
I really *wanted* to do it – because, as someone who drives mostly at 80% throttle, the combination of high speeds at a low engine RPM has always fascinated me.
And it was absolutely worth it: Now, in normal traffic on a North Rhine-Westphalia highway, you can use engine speeds between 1,600 and 3,000 RPM to achieve almost any desired speed in 6th gear: 85 - 170 km/h. On the busier Rhine-Ruhr highways, you can now manage with approximately 2,000 RPM, which equates to 115 km/h.
The maximum speed has decreased slightly; it's now around 205 km/h in 6th gear (but only at 3,600 rpm icon_smile.gif). However, it's still relatively quiet in the car. In 5th gear, it would probably go faster, but I don't really care about that.
I can't yet provide an assessment of the driving experience, as I haven't needed to refuel yet. However, I will observe this over several tankfuls before I can offer a reliable evaluation.
Translated on 09-09-2026, 0:23.
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 TDI Speed Sensor Wiring Diagram ACV G22 On-Board Diagnostics (OBD)
No new posts 5-Speed Gearbox: Sharan/Alhambra/Galaxy (AFN) Change? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts Speedometer signal: 6-speed same as 5-speed? Transmission, Chassis, Body & Interior
