Speed Signal Problem Ibiza 6K AFN - K-Power
sunny
Post25-02-2005, 17:46    Subject: Speed Signal Problem Ibiza 6K AFN - K-Power Quote
I'm having a problem with the logs for K-Power. Specifically, my speed signal is 'acting up' icon_confused.gif.
I have tried various measurement devices using VAG-COM Ver.409.1 (Shareware + DIY adapter icon_biggrin.gif), and all values can be easily read and logged. However, the crucial km/h values randomly jump to the actual speed icon_arrow.gif, resulting in no correct measurement values icon_arrow.gif, and K-Power is not possible.
The speedometer is working perfectly; there are no erratic readings or anything like that.
The error log shows an 'implausible speed signal' icon_arrow.gif. The error was cleared, and a new measurement was performed. The result is that when accelerating, the km/h display works correctly. However, when disengaging at maximum RPM, it shows 0 km/h, and then various km/h readings icon_eek.gif icon_arrow.gif. This measurement is useless icon_evil.gif.
After that, the car was parked (ignition off and on), and the error memory was read again icon_arrow.gif. Empty, no entries icon_eek.gif.
I've done some digging through the search results and have come to the following conclusion (please correct me if anything is wrong icon_redface.gif).
There is a sensor that provides a speed signal, outputting two signals. One signal goes to the control unit (KI), and the other goes to the engine control unit (ECU).
The signal for the AI seems to be working correctly, as the speedometer is functioning properly.
with the other signal, something isn't right (possibly a loose connection icon_arrow.gif, as it works when accelerating).
My question is, where is the installation location of this sensor (is it called a G22 speed sensor? Apparently, it seems to be called that according to my search icon_redface.gif)?
Are these both the same signals, or do the Mstg and the KI operate with different signals?
From that, I could draw conclusions about whether the sensor is defective or if there's a problem with the 'signal line' leading to the MSTG (Multi-Sensor Test Gauge).
Can I measure anything there? The signal is probably only measurable while the vehicle is in motion icon_rolleyes.gif.
I've encountered the 'implausible vehicle speed' error multiple times, and after clearing it, I haven't noticed any negative effects while driving. There's been no hesitation, no loss of power.
Thank you in advance.
'MFG' is an abbreviation for 'mit freundlichen Grüßen,' which means 'best regards' or 'sincerely.' It is commonly used in German-language emails and letters.
Translated on 25-10-2026, 2:14.
Post25-02-2005, 17:55    Subject: Speed Signal Problem Ibiza 6K AFN - K-Power Quote
The speed limiter should be located on the differential.
I can only speculate as to how those specific control units came to be, so I won't comment on that.
Translated on 25-10-2026, 2:17.
sunny
Post25-02-2005, 18:26    Subject: Speed Signal Problem Ibiza 6K AFN - K-Power Quote
Okay, then I'll take a look when it's a bit warmer (-8°) icon_mad.gif.
@Rainer
if you're already there, a quick question about K-Power icon_biggrin.gif.
Do I need to start the log exactly at 1500 RPM, or can I start it a little earlier? And how long do I need to keep the clutch disengaged while rolling before I can end the log?
The issue is that when I take measurements in the third gear, my 'test track' will eventually become too short to fully accommodate the vehicle's rollout (without any curves or hills).
On the A4 highway, it also takes quite a while to slow down from 170 km/h, and then a hill starts, which certainly affects the speedometer reading.
Translated on 25-10-2026, 2:18.
Post25-02-2005, 20:09    Subject: Speed Signal Problem Ibiza 6K AFN - K-Power Quote
Of course, you can start the measurement whenever you like icon_smile.gif.
For a TDI engine, it's generally advisable to start increasing the RPMs from 1500 RPM.
When deploying, it typically reaches about half of the starting speed, and the rest is then interpolated.
The measurement will simply be slightly less accurate in the area where data is missing.
Translated on 25-10-2026, 2:20.
Hati
Post25-02-2005, 20:37    Subject: Speed Signal Problem Ibiza 6K AFN - K-Power Quote
@ Rainer
... Let it idle until it reaches half of its starting speed...
Hmm, did I make a mistake in my thinking there? icon_redface.gif or did you mean something completely different?
Post25-02-2005, 21:52    Subject: Speed Signal Problem Ibiza 6K AFN - K-Power Quote
Äh sorry, dings. Need a vacation.
I meant half the speed between the start and end of the measurement.
If you ever look at a diagram showing the curve of traction force on a proper dynamometer, everything should become clear. When rolling out, the traction force initially drops sharply and then gradually decreases.
I'm going to bed now...
Translated on 25-10-2026, 2:21.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts K-Power Seat Ibiza Cupra: Measuring Data Block Question On-Board Diagnostics (OBD)
No new posts Threaded suspension Ibiza GT TDI - Problem ?????? Transmission, Chassis, Body & Interior
No new posts Speed Signal: Where to Find It? Diesel Engine Technology
No new posts GRA Switch and Speed Signal Diesel Engine Technology
