Boost AFN Turbo Pressure: 22k Ohm Resistor?
MichaC.
Karma: +9 / -0   Thank you, like it!
Post25-02-2005, 20:53    Subject: Boost AFN Turbo Pressure: 22k Ohm Resistor? Quote
Hello forum,
This is my first post today, after having read a lot here for a long time. icon_wink.gif
My question:
I drive a 1998 Seat Toledo with an AFN engine and a Speedbuster tuning box. I want to slightly increase the boost pressure, aiming for approximately 0.15 bar. I was thinking I could achieve this with a 22kOhm resistor. Or, as described in this forum, should it be an 18kOhm resistor (0.1 bar) or a 27kOhm resistor (0.2 bar)?
My car has a boost pressure gauge, which means I can easily monitor the increase in pressure.
"Micha"
Translated on 16-10-2026, 9:26.
Post26-02-2005, 9:01    Subject: Boost Turbo Pressure on AFN Engine: 22k Ohm Resistor? Quote
MichaC. wrote:
I drive a 1998 Seat Toledo with an AFN engine and a Speedbuster tuning box. I now want to slightly increase the boost pressure. I'm thinking of about 0.15 bar. I suppose I could achieve this with a 22kOhm resistor? Or, as described in this forum, should it be an 18kOhm resistor (0.1 bar) or a 27kOhm resistor (0.2 bar)?
My car has a boost pressure indicator.
This means I can easily monitor the increase in boost pressure! }
As a first approximation, you are likely correct with 22k for 0.15 bar.
The specifics of how this all works in practice are a different matter. But you can easily monitor it using LDA -> so just try it out, and during test drives, be very careful and gradually increase the pressure with your foot to feel for the maximum pressure.
Translated on 16-10-2026, 9:28.
MichaC.
Post26-02-2005, 9:41    Subject: Boost AFN Turbo Pressure: 22k Ohm Resistor? Quote
Hello Ulf,
Thank you for your reply!
I'm going to try a 22kΩ resistor today.
"Micha"
Translated on 16-10-2026, 9:30.
MichaC.
Post27-02-2005, 16:52    Subject: Boost AFN Turbo Pressure: 22k Ohm Resistor? Quote
I had my brother-in-law (an electrician) solder a 27kOhm resistor in yesterday. I now have approximately 1.5 bar as an overshoot and 1.1 bar set as the regulated pressure. The smoke development during acceleration is now practically non-existent! icon_wink.gif
I won't be spinning the rod for now. Even though the overhanging parts are quite substantial.
"Micha"
Translated on 16-10-2026, 9:31.
No new posts Error Zünder 1 for Airbag (Passenger Side) - N131 Resistor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Increase for ALH Engine - Help Needed! Diesel Engine Technology
No new posts Bi-turbo in the VW? Is that okay? Diesel Engine Technology
No new posts LMM: Resistance and Challenges Diesel Engine Technology
No new posts Can Xenon control units be coded with VCDS? On-Board Diagnostics (OBD)
