Missing Data Frame Signal: Troubleshooting Guide
DeathAngel69
Post04-08-2002, 16:01    Subject: Missing Data Frame Signal: Troubleshooting Guide Quote
Hello.
I have a 120A alternator installed on my 1Z engine. Unfortunately, instead of a DF signal wire, it has a W-terminal. Can I simply apply 12V to the DF cable, or what is required? I think that the 120A alternator should be able to power the glow plug heating system in the water channels regardless of the climate. And since I almost never drive short distances, the generator load shouldn't be a problem anyway? Am I wrong about this??
Translated on 01-08-2026, 9:17.
Post04-08-2002, 22:07    Subject: LiMA Capacity: What You Need to Know Quote
Hi.
I'm not entirely convinced that the 120A LiMa can handle the glow plug heating system in every situation – if that were the case, mine wouldn't switch off during extended idling (I also have a 120A one).
I'm not exactly sure how to reproduce the signal.
However, an internal DF terminal should also be present on your alternator. Perhaps it would suffice to simply connect this terminal and run a wire from it to the DF input of the engine control unit.
Translated on 01-08-2026, 9:18.
DeathAngel69
Post04-08-2002, 22:28    Subject: Missing Data Frame Signal: Troubleshooting Guide Quote
Sure, you're welcome.
Has anyone ever done this before? Does anyone know where I should start looking?
That's a good start. I'll take the bra apart tomorrow or the day after and see what I find.
Thank you.
DeathAngel69
Translated on 01-08-2026, 9:19.
Post04-08-2002, 22:41    Subject: Find DF Connector: Types & Where to Buy Quote
Hi.
IMO, one of the carbon brushes should always be connected to the regulator on the DF (Differential Frequency) side. The other ("incorrect") brush would then be connected to ground or a constant positive voltage.
Translated on 01-08-2026, 9:20.
DeathAngel69
Post08-08-2002, 6:37    Subject: Solution Approach: A Practical Guide Quote
Hello again.
Okay, I've checked everything again.
The damn wiring harness (originally purchased for €571). It had a shoddy finish. The second cable wasn't properly connected to the plug. There was absolutely no contact. Now, at least it doesn't show any errors in the control unit anymore. icon_biggrin.gif
It's really sad --> It's an original part, and then there's a manufacturing defect like that. I'm really angry about it.
Translated on 01-08-2026, 9:21.
Post08-08-2002, 16:19    Subject: Premium Quality: The Real Deal? Quote
Hi.
... or did you perhaps get a counterfeit wiring harness (like a Rolex copy) icon_razz.gif?
Here's the translation:
"Another question: Why does your signature say "LLK"? That usually means "Low Pressure Pump," and every TDI, including the 1Z, has it as standard equipment..."
Translated on 01-08-2026, 9:23.
DeathAngel69
Post08-08-2002, 16:37    Subject: Quality: What Matters Most? Quote
I seriously doubt that's quality. It was placed there because...
I bought a 1992 Passat with a 2-liter automatic transmission engine. Now I've converted everything to TDI. It wasn't really easy, especially since there were hardly any examples to follow and very little information available. But with a lot of luck and the help of many forums and resources, I managed to get it done.
Therefore, I didn't really have a clear idea of what truly belonged and what didn't icon_smile.gif.
That's why I sometimes ask what might seem like 'stupid' questions!
Thank you and have a nice day.
Translated on 01-08-2026, 9:24.
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts "Missing" Control Unit 76? Parking Assist? Electrical Systems, Vehicle Electronics, Multimedia
No new posts A4 2.5 TDI G28 - No Signal Diesel Engine Technology
No new posts TDI Signal Consumption Measurement 1Z Diesel Engine Technology
