Author: Michael II
The windshield is cracked, starting from the bottom edge.
Cause:
Damage to the windshield – specifically in the lower area – caused by improper removal of the cowl cover from the windshield.
Windshields that have been torn from the bottom edge show that the cover for the water reservoir is still being improperly removed!
Solution:
Spare part.
The water tank cover must not be removed using any tools above the windshield.
Reason:
The tool creates notches and scratches in the glass that can lead to cracks in the windshield during operation.
By lifting either the left or right corner, the cover can be unfastened.
Please provide the German text you would like me to translate into English. I will then give you only the translation, without any explanations.
Bye.
Michael.
Translated on 24-07-2026, 4:24.
