Author: Michael II.
Engine idling roughly.
Poor compression readings on cylinder bank 2.
Error entry in the engine control unit: Camshaft position sensor, bank 2, not communicating with the crankshaft sensor.
Cause:
Due to tolerances, it is possible for the camshafts to be misaligned relative to each other on cylinder head 2.
Solution:
After repairing the cylinder head (bank 2) and adjusting the camshaft timing, the engine crankshaft must be rotated 720 degrees after reassembly. Then, the timing marks on the gears must be precisely aligned with the marks on the bearing cover.
Please provide the German text you would like me to translate.
Bye.
Michael.
Translated on 21-09-2026, 4:57.
