Hi.
Given that critical errors that would completely prevent a mechanically sound engine from starting are usually stored in the error memory, I suspect the problem is "no fuel."
Check if the transparent pipe connecting the filter to the pump is completely full of water, or if it contains long air bubbles.
To be absolutely sure, disconnect the fuel return line from the filter and have an assistant briefly engage the starter motor; this should pump diesel fuel.
If that's the case, the fuel pump won't receive any fuel. As a test, try adding approximately 100 ml of verschandeln diesel fuel directly into the pump through the inlet line; it should then start (be careful of potential...). Fountain on the return line!
If nothing else works, the valve seat might be stuck --> unscrew it and check the valve seat for any ridges or imperfections, and smooth them out if necessary. Alternatively, you could try removing the valve stem completely, re-installing the upper part, and then starting the engine.
If then, despite diesel being in the pump, nothing still comes out
and the error memory is empty, then the pump probably has a new problem
