Tuning Box for Wendland Vehicles
sascha
Post10-08-2002, 16:11    Subject: Tuning Box for Wendland Vehicles Quote
I bought a used tuning box for a 1.9 TDI 110hp Audi A4, manufactured in 1997.
The box has a hose connection; where should I connect it?
Thank you.
Alex.
Translated on 06-08-2026, 1:21.
Post10-08-2002, 17:27    Subject: Hose Connector: Types & Applications Quote
Hello Sascha,
For the auxiliary box, this is the connection for the boost pressure. The box is activated (or deactivated) depending on the boost pressure.
Translated on 06-08-2026, 1:22.
sascha
Post11-08-2002, 11:36    Subject: Tuning Box for Wendland Vehicles Quote
I couldn't find a connection for the charging cable. (Everything is controlled using the under-pressure system.)
Post11-08-2002, 12:41    Subject: Tuning Box for Wendland Cars - Performance Upgrade Quote
sascha wrote:
I couldn't find a connection for the charging cable. (Everything is controlled with the
underlying system).
Hi.
The (VTG) supercharger is controlled with
pressure to regulate the boosthttp://www.diesel-schrauber.de/forum/messages/135.html pressure.
Starting from the Authalbox, you need to tap into the boost pressure.
Depending on the version of the engine control unit, a thin hose runs from the intake manifold (behind the intercooler) to the engine control unit. This hose can be tapped into using a T-connector.
Alternatively, if the boost pressure sensor is located directly in the intake manifold, then the pressure tap needs to be created manually.
An example: }
Translated on 06-08-2026, 1:24.
No new posts Wendland - ABE On-Board Diagnostics (OBD)
No new posts Engine tuning box installation Diesel Engine Technology
No new posts Tuning Box: Save 1L Fuel Per Trip Diesel Engine Technology
No new posts Tuning Box for Galaxy 1997 Diesel Engine Technology
